Wiring Undercar LEDs
Posted: Mon Feb 28, 2005 8:25 am
by LesPaul
hey all, I have all 4 LED tubes mounted, but i couldent find a way to run the wires through the firewall . is there a way i can run wires through the firewall without taking off the dash.Thanks
Re: Wiring Undercar LEDs (LesPaul)
Posted: Mon Feb 28, 2005 9:56 am
by oolunchbox
When I installed the power wire for my amp i ran it through the grommet that all the wires from the steering column run through. there's a thread on here about doing an amp install that runs the wires through there, basically you just need to stick a screwdriver through there to make a little room for the wires and fish 'em through.
Re: Wiring Undercar LEDs (oolunchbox)
Posted: Mon Feb 28, 2005 10:21 am
by Smokin' Rubber
yeah its kind of a pain to do but tape the wires onto the tip of the screw driver and force it thru then just untape it once the wire is poking thru inside the car and pull it as far as you need (also just FYI the rubber grommet is already a really tight fit so shoving things in isn't the easiest thing in the world you might have to make a small cut in it as well)
