check out ebay 2 nav sys complete under $100 each
Posted: Fri Feb 25, 2005 1:18 pm
by jim
ebay # 5753772978 5753774784looks like a good deal if you want one, looks like the one in the VIBE/MATRIX, but I would check with the seller first.
Re: check out ebay 2 nav sys complete under $100 each (jim)
Posted: Fri Feb 25, 2005 10:09 pm
by Jahntassa
It physically looks like the same one, but if it was pulled from a Toyota, and not specifically a Matrix, you'd have to find toyota wiring harnesses and create a GM -> Toyota harness. Not that it WOULDN'T work, but you'd have to take the extra step.As usual, there's no CD changer with the auction, so you wouldn't be able to play CDs and do NAV at the same time.
Re: check out ebay 2 nav sys complete under $100 each (Jahntassa)
Posted: Sat Feb 26, 2005 2:56 am
both those auctions are over, one went for $330, the other for $395
Posted: Sat Feb 26, 2005 9:52 am
by champcaracing
ok i got a factory toyota 05 camry set up, had to mod the radio bezal, and make a harness for the body to amp/radio harness with the jbl amp. but now have a small problem with the rear speakers, think i have it figured out gonna try something sunday and if it works, i'm replacing all the speakers with bostons' everything works fine right know, but the sound. hopefully what i try sunday works and i'll have this whole project wrapped up by friday.
