New CAP installed
Posted: Thu Feb 24, 2005 12:47 pm
by Merzbow
Well, my system was not on the top of my priority list but I just kept adding and adding to it, couldn't resist. My friend got a shiny new red capacitator and I liked how it performed and looked a lot so I got one myself for $50 from a friend that hooks us up.Mine was actually brushed aluminum and orange/red/yellow flames but I traded my friend for his red one (only one day old) since it matches my red/black theme. It looks and works awsome. By the way it is a WölfenHagen...not sure if it's a goodbrand name but it works and I like it.I have it sitting on the floor for now but I am milling up some custom aluminum brackets for it in metal shop and I'm going to mount it on the passenger side in front on the side of the carpet under the glove box next to the shifter. I will put the brackets under the carpet and bolt the CAP to the bracket with the carpet in between becaause I don't wana drill into any metal. Also right now I'm using wire i got from the hardware store as temporary wire. Once I get some real 4 gauge power wire I will re-route it to my desired position. the wire on there now is soooo corse its like a 4 gauge copper rod lol...
Re: New CAP installed (Merzbow)
Posted: Thu Feb 24, 2005 12:48 pm
by Merzbow
In the dark. Blue LED and red digital display.
Posted: Thu Feb 24, 2005 1:04 pm
by damronjr
Looks good! Hope nobody has to sit back there!
Re: New CAP installed (damronjr)
Posted: Thu Feb 24, 2005 1:27 pm
by Merzbow
lol, i make them sit on the left for now. That's why I'm moving it. It says to keep it as close to the amp as possible. The amps under my seat so the place I plan to permanentally mount it is a good spot to show it off and keep it out of the way.
Posted: Thu Feb 24, 2005 2:52 pm
by Smokin' Rubber
Looks nice Merz, I just got a new CAP too should be here in a couple days I decided to go with a 2 FARAD Boss so it could handle the 1,800 drain from the ampi'll post pics when I get it
Re: New CAP installed (Smokin' Rubber)
Posted: Thu Feb 24, 2005 11:11 pm
by nismo
Nice install man. I'm not a big fan of that brand. But I haven't really heard much of them. I heard their subs they make once. They sounded alright.Inder
Re: New CAP installed (TRD4reel)
Posted: Fri Feb 25, 2005 1:36 am
by drunkenmaxx
what exactly are the benefits of a cap? is there a way to tell if you need one?
Re: New CAP installed (drunkenvibe)
Posted: Fri Feb 25, 2005 1:52 am
by russ257
a cap helps smooth out the power to the amp. if your lights dim when your sub hits you prolly need one.
Re: New CAP installed (russ257)
Posted: Fri Feb 25, 2005 2:18 am
by damronjr
Quote, originally posted by russ257 »a cap helps smooth out the power to the amp. if your lights dim when your sub hits you prolly need one. Stole the words right out of my mouth, but in the case of the Vibe, my lights still dim a little WITH a 1 Farad Boss cap!
Posted: Fri Feb 25, 2005 2:57 am
by Merzbow
Yeah it didn't help with the lights dimming. They don't dim when the subs hit but they dim when I roll down the windows. How can I tell how many Farads the cap is? I couldn't find the label.
Posted: Fri Feb 25, 2005 3:01 am
by Smokin' Rubber
See if it has a model number then just look it up online or something MerzAlso, it seems to me that when you have a capacitor installed the amp overheats less (or thats how it seemed whe my friend and i were messing with his system with and without the cap).
Posted: Fri Feb 25, 2005 3:03 am
by drunkenmaxx
kind of looks like a bomb!
Posted: Fri Feb 25, 2005 6:32 am
by Merzbow
(removed), it kind of is one. If you touch both terminals it'll give oyu a heaart attack lol. Probably not that bad but I'm sure if I stabbed someone with it it would hurt.....like a tazer.
Posted: Sat Feb 26, 2005 2:19 pm
by Merzbow
Ok so in the process of remounting my CAP, it blew somehow. I got a new one for free. This one is also red with a red LED instead of blue. This one's stronger as well. It's 1.5 Farens. I will take pics of it tomorow and also of my sweet mounting position.
Posted: Sat Feb 26, 2005 9:43 pm
the capacitor is only storing 12V DC right? so if you touched both terminals, your body resistance would be so high that there would not be enough current to do any damage. If you got a metal conductor across both terminals, you'd probaby see some serious sparks, but your body isn't a good enough conductor to have any trouble with 12V Just don't lick it or something stupid. You could probably invent some way to have it hurt, but just contacting 12V is not deadly.
Posted: Sat Feb 26, 2005 10:39 pm
by Jahntassa
You are charging the cap with some sort of resistor before connecting it to the battery, right? Caps like these need to be charged up, otherwise they'll get really unhappy and eventually fail.
Re: (Jahntassa)
Posted: Sun Feb 27, 2005 12:42 am
by Merzbow
Yeah I had it moved and it wasn't charging or discharging so when I had my friend look at it I think he touched the positive power cable to the negative because it sparked real bad and it blew my fuse in the amps power line. I couldn't see what he did cause his head was in the way. He took my cap and tested it on his system and it blew his fuse as well so he exchanged it for my new one and bought me a new fuse. This one is running at 13.8volts and the other one ran at 14.4.Here are the new pictures. I am going to turn the cap around and wire it up under the carpet once I get some real power wire because this sh*t I'm using now is waaay to strong to bend at the angles I would need.
Re: (Merzbow)
Posted: Sun Feb 27, 2005 12:43 am
by Merzbow
The mounting spot.
Re: (Merzbow)
Posted: Mon Feb 28, 2005 12:24 pm
by Celtic_Curse
Merz I like the cap however in my end of the woods that would be stolen in about 15 minutes. Is that the permanent spot?
Re: (Celtic_Curse)
Posted: Tue Mar 01, 2005 11:52 am
by Merzbow
Yeah, I'm going to turn it around when I get real stereo wire so the terminals arn't jabbing into people's legs and giving them heart attacks. I park in the garage and if I'm not home I keep a close watch on her. Also no one around here knows what a CAP is. They all think it's some kind of bomb or tazer when I show them. AND as an extra precaution I put my cd books in front of it when I leave so you can't see it from outside My amps unde rhte seat out of sight and subs are under the cargo cover in the back.
Posted: Tue Mar 01, 2005 4:12 pm
by Jahntassa
Now..wait a minute...how do you have that cap hooked up? There should be at least three hookups. - Ground to chassis- +12v from battery- Output to amp The last two should both be going to the positive terminal..I only see two wires on yours?
Re: (Jahntassa)
Posted: Tue Mar 01, 2005 10:35 pm
by damronjr
Quote, originally posted by Jahntassa »Now..wait a minute...how do you have that cap hooked up? There should be at least three hookups. - Ground to chassis- +12v from battery- Output to amp The last two should both be going to the positive terminal..I only see two wires on yours?Hmm, I didn't even notice that! Hope he doesn't just have it run from the +/- of the amp instead of off of the power wire before the amp!
Re: (Jahntassa)
Posted: Wed Mar 02, 2005 12:55 am
by Mase
You can easily daisy chain the cap to the amp's (+ BATT) terminal. It looks a lot cleaner IMO when you have only 1 wire per terminal on the cap. All splices should be made with a junction block. Caps don't normally provide enough amperage to need a dedicated wire to the battery and another to the amp.
Re: (Celtic_Curse)
Posted: Wed Mar 02, 2005 7:22 am
by Psychobroker
Quote, originally posted by Celtic_Curse »Merz I like the cap however in my end of the woods that would be stolen in about 15 minutes. Is that the permanent spot? Yeah bro, might want to move it again. Here's where I mounted mine:Quote »My amps unde rhte seat out of sight and subs are under the cargo cover in the back.Ahh, I see why it'd be hard to mount them in the back. You should mount the cap as close to the amp as possible with as little wire as possible, so unless you move the amp, it'd be pretty far from it.
Re: (Psychobroker)
Posted: Wed Mar 02, 2005 7:39 am
by Merzbow
I wired it into the positive cable before the amp. and the neg is going to ground undercarpet Yeah I put it there because the amps under the seat and because I think it looks neat.
Re: (Merzbow)
Posted: Wed Mar 02, 2005 8:03 am
by Psychobroker
Quote, originally posted by Merzbow » because I think it looks neat.you know what Merz? That's really all that matters
Re: (Psychobroker)
Posted: Wed Mar 02, 2005 11:42 am
by Merzbow
(removed)! Is that a nice way of saying "You're such a stupid @$$ installing it wrong that I'm just going to pretend I didn't see it" I know that's what you're thinking lol.Just wait til I get my 56" spinnaz and my 54inch flip down plasma and then we'll see who's dumb (removed)!
Re: (Merzbow)
Posted: Thu Mar 03, 2005 2:03 am
by Psychobroker
Quote, originally posted by Merzbow »(removed)! Is that a nice way of saying "You're such a stupid @$$ installing it wrong that I'm just going to pretend I didn't see it" I know that's what you're thinking lol.Just wait til I get my 56" spinnaz and my 54inch flip down plasma and then we'll see who's dumb (removed)!hahaha ROFLMAO
Re: (Psychobroker)
Posted: Thu Mar 03, 2005 3:38 am
by Merzbow
Yeah dawg, my dad gave me $18000 to buy something so Ima buy sum phat azz dub duces and paint hte spinna to match the Escalade I found under a rock in Detroit.Sigh...if I had 18grand I'd buy myself an S14 Silvia and a '68 Baracuda to modify the hell out of.
Re: (Merzbow)
Posted: Thu Mar 03, 2005 1:31 pm
by Smokin' Rubber
Sweet I just got my new cap today! gonna install it this weekend
Re: (Smokin' Rubber)
Posted: Fri Mar 04, 2005 6:53 am
by Merzbow
lemme see pics! I was lookin in a magizine and it was selling the digital counters for the CAPS for $130!!!!!!!!!!!! Just for the counter! Mine was $50 including the LED and digital counter. I got mine for factory price though
Re: (Merzbow)
Posted: Fri Mar 04, 2005 7:31 am
by Psychobroker
I paid about 50 bones for my cap too....$130 for the counter?!?! What's it do, watch your weight as well?!
Re: (Psychobroker)
Posted: Fri Mar 04, 2005 8:02 am
by rcasciola
and the purpose for this is?!?!
Re: (Merzbow)
Posted: Fri Mar 04, 2005 8:41 am
by Smokin' Rubber
Mine was 62 shipped, but it is 2 FARADS
Posted: Sat Mar 05, 2005 12:19 am
by Merzbow
Yeah see it seems that everyone got a good deal I don't see how they get off selling a digital volt counter for $130!?!?!?rcasciola I think we mentioned the function of the cap somewhere back a few posts, if not I can explain it again I like that it looks like a little bomb. When my friends get in the car they are afraid of it which is a good way to stop them from touching it and screwing with the sires because I told them they would probably have a heart attack if they touched it.
Re: (Merzbow)
Posted: Sun Mar 06, 2005 6:28 am
by rcasciola
haha good way to keep friends away..dnt touch it or youll DIE!!!
Re: (rcasciola)
Posted: Sun Mar 06, 2005 11:53 am
by Merzbow
(removed)! They allways get greasy fingerprints on it because they don't know how to close a door wiith the handles! I have little scratches on my door from my ex and her bracelets as well. So yeah the best way to get them to stop is to tell them it will hurt them (removed).
Re: (Merzbow)
Posted: Sun Mar 06, 2005 12:14 pm
by rcasciola
i totally kno what u mean about those finger prints...but are u getting ang sound difference? better or worse?
Re: (rcasciola)
Posted: Sun Mar 06, 2005 12:37 pm
by Merzbow
Personally it sounds a little cleaner. I can tell its working because whne i have it real loud the colts fluctuate when it hits. I'm not sure if it really did make it sound better or it's just my mind wanting it to sound better but it sure seems like it lol.
