Help Please! Speaker wiring color scheme
Posted: Thu Feb 24, 2005 8:31 am
by joserobl
I have the base stereo in my Vibe and decided to replace the stock speakers with some Polk db650's. I've run into a snag though. I started with the rear doors and found that both right and left door speaker wires are red and white not sure which is - or +. Would anyone Know the wiring color scheme for the base Vibe. I tryed the search but all they give me is for the MT system. Your help will be greatly appreciated.
Re: Help Please! Speaker wiring color scheme (joserobl)
Posted: Thu Feb 24, 2005 9:01 am
by damronjr
Red is always +. It applies here as well.
Posted: Thu Feb 24, 2005 9:46 am
by joserobl
Thanks, would you happen to know the color scheme for the front also? Don't know the colors yet cause I haven't taken the panels off.
Re: (joserobl)
Posted: Thu Feb 24, 2005 10:09 am
by damronjr
Posted: Thu Feb 24, 2005 10:15 am
by joserobl
Isn't that for the MT system? I have the base system. Thanks though for the help
Re: (joserobl)
Posted: Thu Feb 24, 2005 10:25 am
by damronjr
Oops, yeah it is. Should be the same colors. If not, just let us know and I'm sure someone has the chart for that.
Posted: Sun Feb 27, 2005 6:46 am
by joserobl
Just to let you know I finished installing the speakers and it wasn't to bad. I ended up tearing apart the stock speakers to use the same brackets. I come to find though that the stock head unit just isn't enough to do the speakers justis. So now I'm looking at installing an amplifier to the stock head unit. Just want to Thank You again for your help on the wiring scheme. You were right it was basically the same except both the rear left and right are red and white.
