right sized turbo
Posted: Mon Nov 18, 2002 2:55 am
by andrewmva
Re: right sized turbo (Salsa!)
Posted: Mon Nov 18, 2002 3:00 am
by andrewmva
try now
Posted: Mon Nov 18, 2002 5:42 am
by Sub-Vibe-R
lets try 1 under the hood and the other in the trunk
Re: right sized turbo (Sub-Vibe-R)
Posted: Mon Nov 18, 2002 6:15 am
by andrewmva
I think that that turbo is for a cruise ship.... it is like 12ft tall
Re: right sized turbo (andrewmva)
Posted: Mon Nov 18, 2002 6:17 am
by Sub-Vibe-R
quote:I think that that turbo is for a cruise ship.... it is like 12ft tallA turbo on a ship. Lets built a twin turbo Titanic
Posted: Mon Nov 18, 2002 6:45 am
by d_m_kolb
On the Coast Guard Cutter I was stationed on we had 2 main diesel engines. V8s with 750 cubic inches per cylinder. The engines were only rated at 750 HP at 750 RPM but they made around 10,000 ft. lbs of torque! We normally ran them at 500 to 600 rpms.Both mains had a blower the size of a 4 clinder 1ZZ and also had a huge turbo also. The engines were 2 cycle and actually wouldn't run with out the forced induction.Those turbos you showed I have no idea what they would go on.
Re: right sized turbo (Admin II)
Posted: Mon Nov 18, 2002 1:48 pm
by Stang2Vibe
They'd go on my dream engine! That would be nice except I think they might hurt the power to weight ratio a bit. I think you could take a pic of someone standing up inside the wastegate and waving hi to mom. My God, thats a Huge turbo!
Posted: Wed Nov 20, 2002 3:42 am
by Mr. Poopypants
quote:On the Coast Guard Cutter I was stationed on we had 2 main diesel engines. V8s with 750 cubic inches per cylinder. The engines were only rated at 750 HP at 750 RPM but they made around 10,000 ft. lbs of torque! We normally ran them at 500 to 600 rpms.Both mains had a blower the size of a 4 clinder 1ZZ and also had a huge turbo also. The engines were 2 cycle and actually wouldn't run with out the forced induction.Those turbos you showed I have no idea what they would go on.THey might be for those huge excavators and dump trucks. I could maybe strap one to the roof of my Vibe, I would have to reroute a few things but I think it could be done. LOL
Posted: Wed Nov 20, 2002 4:48 am
by Stang2Vibe
Do you think I would have to switch to lower compression pistons if I used these on my 2zz engine?
