Underbody neons...
Posted: Tue Feb 22, 2005 6:01 am
by Emerica13
For all you guys who have installed underbody neons, what exactly is involved in the installation process. I am thinking about getting a set, but I want to make sure that I can remove them if necessary without too much difficulty. I'd like to know basically the steps involved with wiring and attaching them to the car and any other tips or bits of info you think would be helpful. Thanks a lot!
Re: Underbody neons... (Emerica13)
Posted: Tue Feb 22, 2005 7:24 am
by wicked1981
Re: Underbody neons... (wicked1981)
Posted: Tue Feb 22, 2005 7:29 am
by Emerica13
Yeah...sorry about that. Should have looked for other threads first. Thanks wicked
Posted: Tue Feb 22, 2005 2:17 pm
by Merzbow
I have all the info you need in my garage Easy as cup cakes to install and easy to uninstall (I've gotten plenty of tickets) Plus I take them off for winter every year because of the ice and snow! I'm gonna put em back on in March if you wanna join me and install yours too (if you get one).
Posted: Tue Feb 22, 2005 11:49 pm
by MoonDogg
yeah its pretty easy to install... two words for you " TIE WRAPS "
Re: Underbody neons... (MoonDogg)
Posted: Wed Feb 23, 2005 3:55 am
by Emerica13
So do you bolt them on to something under the car or do you use, as you say, "Tie Wraps"?
Posted: Wed Feb 23, 2005 4:03 am
by Merzbow
I bolted mine because roads are ruff. I had to rebolt the rear one like 3 times until I finally riveted brackets into the frame because the screws kept snapping in half thanks entirely to excelent Michigan roads. Ties should work though as long as you keep an eye on it and don't let them get too cold.
Re: Underbody neons... (Merzbow)
Posted: Wed Feb 23, 2005 4:24 am
by Emerica13
Sweet, thanks a lot guys. I think I'll try it with ties first just to see how it goes, then maybe I will bolt them on later. As for the wiring part though, what did it require in terms of connecting them and stuff. Basically what is involved in wiring them up?
Posted: Wed Feb 23, 2005 10:02 pm
by Merzbow
It should come with little cut rubber hoses to slide over the conections of the wires then you just need electrical tape.
