TB Hose ID Please?
Posted: Sun Feb 20, 2005 11:18 pm
by BlueCrush
What are these two hoses (located with thin red arrows) going into the throttle body for and where do they go to. There is one at the top ofthe throttle body:And one at the bottom of the throttle body:Thanks,Brian
Posted: Mon Feb 21, 2005 12:09 am
by tnpartsguy
The top hose is marked "Fuel Rail Injector Feed" The lower hose is marked "Throttle Body Heater Inlet" The part it goes to is marked "Valve, Idle Air Control"There should be a 3rd hose beside the lower one "Throttle Body Heater Outlet"
Re: (tnpartsguy)
Posted: Mon Feb 21, 2005 12:19 am
by BlueCrush
I don't see the third one. Where is that one located?
Re: (BlueCrush)
Posted: Mon Feb 21, 2005 12:40 am
by tnpartsguy
Should be beside the other lower one. They mount in a V into that block.
Re: (tnpartsguy)
Posted: Mon Feb 21, 2005 12:48 am
by BlueCrush
Ahh, yes found the third one. Now which do each of these three hoses do? what is their purpose?
Re: (BlueCrush)
Posted: Mon Feb 21, 2005 2:36 am
by tnpartsguy
The top one feeds fuel from the TB to the Injector rail. The bottom 2 carry coolant to heat the TB so it doesn't ice up. I was kinda surprised to see this, as most cars use an electric heater now. But anyway, that's what they are, and they are all needed for the car to run properly.
Re: (tnpartsguy)
Posted: Mon Feb 21, 2005 2:38 am
by BlueCrush
Excellent! Thank you for the lesson in Throttle Body Hoses 101.
