New/Old Technical Service Bulletins (TSBs) for 2003 Vibe
Posted: Sat Nov 16, 2002 12:13 pm
Did a check on NHTSA.gov's website concerning Consumer Complaints and Technical Service Bulletins for the Vibe. They seem to have a few newer bulletins out including PDF's of the actual GM Voicemail Log that is sent out.The main area on NHTSA.gov's site is http://www.nhtsa.dot.gov/cars/problems/.Here are some of the PDF's linked to specific problems. Pretty cool new feature: Transmission Fluid/Engine Performance: http://www.nhtsa.dot.gov/TSBScans/sb629810.pdf ALC/Sunroof Operation: http://www.nhtsa.dot.gov/TSBScans/sb629728.pdf Hub Torque Bolt Recall: http://www.nhtsa.dot.gov/TSBScans/sb629861.pdf Auto Trans Shifting (temp. related): http://www.nhtsa.dot.gov/TSBScans/sb629850.pdf Engine Cover/Sunroof Water Leak: http://www.nhtsa.dot.gov/TSBScans/sb629757.pdfKeep an eye on that site, as well asTSB's: HereComplaints: HereRecalls: HereIf your Vibe exhibits these problems, definately print out all the information you can on the problem (NHTSA's document AND PDF) when you go into the dealer. The more info the better to help diagnose and remedy your problem.My suggestion, if you so desire , is to get a nice size 3-ring binder and add any and all information pertaining to repairs, warranty issues, upgrades, etc. to the book so everything you need will be easy to find, plus definately show people you care about your vehicle and are determined to keep it running optimally.
