High-pitched whine on Idle - 2003 AWD Vibe
Posted: Wed Feb 09, 2005 8:54 am
by zipfool
We started noticing a high-pitched whine coming from what seems to be under the hood when the car is idling. It's mostly noticeable when we are trying to parallel park, and it sounds almost as if there's a small bird caught under the hood somewhere....and no, I checked there isn't.Has anyone else experienced the same problem?
Re: High-pitched whine on Idle - 2003 AWD Vibe (zipfool)
Posted: Wed Feb 09, 2005 9:00 am
by Raven
Try checking the level of your power steering fluid.
Posted: Wed Feb 09, 2005 9:01 am
by zipfool
It doesn't seem to be motivated by any steering though. If I have my hands off the wheel entirely, I still hear the whine.
Posted: Wed Feb 09, 2005 9:39 am
by fitness freak
Maybe a vacuum hose leak.
Posted: Wed Feb 09, 2005 12:58 pm
by ColonelPanic
Hmm, this is an interesting one! Does the noise only occur at idle? On the last car, I had a whine that was proportional to engine speed -- that turned out to be the alternator. Guess the bearing died in the thing. But, I can't say I heard the whine at idle... Also had a noisy (and leaking) power steering pump that had to be replaced on that car as well.If you open the hood while it's doing it, can you tell approximately where the noise is coming from?
