Gas cap is coated in salt - Anyone else?
Posted: Tue Feb 01, 2005 9:06 am
by thorntcl
I've noticed that the design of the gas filler cap area seems to allow for salt and a lot of road grime to get into the gas cap filler area. This seems to be a ticket for potential problems later from salt and/or getting into the gas tank. My cap is coated with salt and the metal filler tube seems to be getting exposed to this corrosion.The problem seems easily solved if they would have not made the drain hole wide open to the elements below to the wheel well. They should have fashioned a screen or splash shield around the opening so the gas could drain out, but not so easy for the salt and water to get thrown up into the filler cap area.Has anyone else experienced the same problem and if so is there a fix for this?Cheers
Re: Gas cap is coated in salt - Anyone else? (thorntcl)
Posted: Tue Feb 01, 2005 10:39 am
No problems here!
Re: Gas cap is coated in salt - Anyone else? (ragingfish)
Posted: Tue Feb 01, 2005 10:40 am
by nismo
I'll let ya guys know tomorrow when I go to fill up my tank.Inder
Posted: Wed Feb 02, 2005 12:18 am
by Mase
I don't have a problem with salt getting in there since I live in the desert, but I get dirt and dust crusted in there every so often. We have dust storms out here periodically. Maybe there's a way to line the compartment with weather stripping?
Posted: Wed Feb 02, 2005 12:56 am
by ToolGuy
Have not noticed anything out of the ordinary... Possibly your area uses too much salt?Make a gasket for you fuel door, I dunno...
Re: Gas cap is coated in salt - Anyone else? (MiVibe-ToolGuy)
Posted: Wed Feb 02, 2005 11:59 am
by Mavrik
Mine is clean. no probs yet.
Re: Gas cap is coated in salt - Anyone else? (Mavrik)
Posted: Wed Feb 02, 2005 12:00 pm
by nismo
Yeah. I checked mine as well today, clean.Inder
Re: Gas cap is coated in salt - Anyone else? (TRD4reel)
Posted: Thu Feb 03, 2005 9:14 am
by thorntcl
Thanks Inder and the rest of your help guys.Being in Ottawa Canada, you can't see the pavement for all of the salt on the road. Safe to have clean roads, but the car sure takes a beating. I rustproofed the car just to be safe.Weatherstripping sounds like an idea too.I'll bring it into the dealership in the spring to see if anything can be done.
Posted: Thu Feb 03, 2005 10:17 am
by Gala
I havn't noticed such a thing man. Get that checked b4 your waranty runs out.
Posted: Thu Feb 03, 2005 11:22 am
by Raven
I filled up today in Ottawa and mine is covered in salt. I got the Vibe washed too and I bet it lost 10 pounds. The salt was falling off it in big sheets about 2mm thick. It's the first day the temperature went above freezing in about 3 weeks.
