Aftermarket "manual" auto transmission???
Posted: Wed Jan 26, 2005 2:54 am
by Z600
Sorry, I don't know what they actually call them. The auto transmissions that allow you to manually change the gears ( usually by a "+" or "-" area on the shifter).It seems like it would be a simple thing to make (if not to install). Has anyone ever seen such a thing? All you would need is just a simple push button assembly that interrupts the signals from the computer and manually tells the tranny when to shift and what direction... doesn't seem like a terribly complex invention. I've not seen one, just something I was wondering about.~ Z600
Re: Aftermarket "manual" auto transmission??? (Z600)
Posted: Wed Jan 26, 2005 4:51 am
by nismo
Well, technically, you can do that. But I know what you're talking about. It's called Manumatic.
Re: Aftermarket "manual" auto transmission??? (TRD4reel)
Posted: Wed Jan 26, 2005 5:09 am
by damronjr
Quote, originally posted by TRD4reel »Well, technically, you can do that. But I know what you're talking about. It's called Manumatic.I couldn't remember the term for it. Yeah, I pretty much do that now at least from 1st to 2nd and 2nd to 3rd. After that you don't have much control since it's an automatic. I know some cars are made with that where you can shift it manually or let it go automatic.
Re: Aftermarket "manual" auto transmission??? (damronjr)
Posted: Wed Jan 26, 2005 6:02 am
by nismo
Well, you can go from 1st to 2nd, 2nd to 3rd, and 3rd to overdrive. That's what I did for a little bit.
Posted: Wed Jan 26, 2005 8:23 am
by tecton
doesnt matterwhole point of a manual tranny is to have a clutchautos are too fragile for too much powerdont worry about finding a manumatic tranny...find us a higher stall torque converter
Posted: Tue Feb 01, 2005 1:36 am
by Moms04Vibe
actually......i am planning to do a auto to 6 apd manual tranny from an 05 vibe when i find a wrecked GT or something.
Re: (Moms04Vibe)
Posted: Tue Feb 01, 2005 1:58 am
by nismo
Nicee. Wouldn't you have to change the ECU as well? Other than the tranny parts?
Posted: Tue Feb 01, 2005 5:21 am
by Jahntassa
Many places will use the term "Tiptronic" shifter, or clutchless manual as well..
