Underbody Neon's
Posted: Mon Jan 24, 2005 12:38 am
by MoonDogg
I am installing underbody Neon's and have got all the wires ran and the front neon mounted and know how I am mounting the sides (just waiting to put it on lift at friends shop) but I am still tring to figure out were to mount the back one. I tried putting it behind the bumber mounts, but that did not work.. any sugestions or picutes would be greatly apriciated. Thanks in advanced.
Re: Underbody Neon's (MoonDogg)
Posted: Mon Jan 24, 2005 2:41 am
by Merzbow
I attatched my rear ones on the rear cross bar of the chassis. The cross bar is curved though so it kept breaking the screws. So basically I looked like a moron driving around with one side of my neon tube peeking out. So to solve this problem I used two "L" brackets about 3"x3" or so and atatched them to the chassis and then attatched the tube to the brackets. it helps absorb more shock from the bumps and also brings it lower to the ground. Since the rear of the chassis is high off the ground, if you just bolt it to the chassis it wont be as bright If you need me to take pictures of the installation point or something let me know I just got a shiny new camera for xmas
Re: Underbody Neon's (Merzbow)
Posted: Mon Jan 24, 2005 4:43 am
by MoonDogg
Yes yes yes.. pictures would be wonderfull!!! how they say that.. a picture is worth 1000 words...
Posted: Mon Jan 24, 2005 4:59 am
by scherry2
I just made 3 peices of 1x2 inch metal plates screwed them to the frame and screwed the neon brackets to them. same Idea as merzbow just done a little different.
Posted: Mon Jan 24, 2005 5:36 am
by Jahntassa
I think I remember using cable ties to secure the back one...i'll have to take a look and see exactly what I did.
Posted: Tue Jan 25, 2005 8:34 am
by MoonDogg
Anyone with pictures? Would be greatly helpfull... and when I am done I will get pictures and post them here...
Posted: Tue Jan 25, 2005 1:14 pm
by Merzbow
Once again, excuse the salty/slushy car, too cold to wash now.
Posted: Tue Jan 25, 2005 1:15 pm
by Merzbow
#2
Posted: Tue Jan 25, 2005 1:16 pm
by Merzbow
#3I can try to get better pics tomorow when it's light out. I think if I were to use just a flat bracket instead of an L bracket it would be even brighter on the ground since the L bracket raises the tube about 2 inches higher. I was more concerned with the tube getting mounted on a flat surface instead of the curved chassis that I didn't think about how close I wanted the tube to the ground.
Posted: Tue Jan 25, 2005 9:01 pm
by MoonDogg
Thanks a bunch... that definatly points me in the right direction... luckily I work in a machine shop.. brackets should be easy to make
Posted: Tue Jan 25, 2005 10:41 pm
by Merzbow
That's a good idea, I have metal shop class right now! lol, I was thinking of making a new aluminum battery tie-down.
Posted: Wed Feb 02, 2005 11:00 pm
by MoonDogg
Thanks for all the help.. I got them on last night.. and they look good.. I will get some night pics tonight and post them later on...
Posted: Fri Feb 11, 2005 6:30 am
by MoonDogg
Well I finaly got the pics of how I got the back one on... I will try and take night pictures tonight... here are the pictures [IMG]http://www.billetcnc.com/vibegt/neon's/1.jpg[/IMG] [IMG]http://www.billetcnc.com/vibegt/neon's/2.jpg[/IMG] [IMG]http://www.billetcnc.com/vibegt/neon's/3.jpg[/IMG]
Posted: Fri Feb 11, 2005 6:37 am
by MoonDogg
Looks like something wrong with html tags... copy and paste links and should get pics...
Posted: Sat Feb 12, 2005 3:37 am
by Merzbow
I'm guesing thats the back tube! I can't wait to see the night shots! I was debating on putting mine on today since its like 40 degrees out!!! Pathedic how 40 degrees feels warm now. I think I'm gonna wait til March though I don't want to get any ice on it. I'lll be installing the transformer and maybe the front and rear tubes today though. The front and rear wont work until I get the sides in but that's fine. Just less work to do and more time to enjoy it when March rolls around.
Posted: Mon Mar 28, 2005 11:09 pm
by MoonDogg
Well.. over a month later.. I got night shots... I am only going to post the good ones Tell me what you think...
Posted: Mon Mar 28, 2005 11:10 pm
by MoonDogg
Next...
Posted: Mon Mar 28, 2005 11:13 pm
by MoonDogg
Posted: Mon Mar 28, 2005 11:14 pm
by MoonDogg
no flash...
Posted: Tue Mar 29, 2005 12:12 am
by Merzbow
that looks wonderful on the fusion! Do you get alot of stares?
Posted: Tue Mar 29, 2005 1:31 am
by MoonDogg
yeah... an't got pulled over yet either... "knocks on wood"
