Tried installing short ram intake...
Posted: Wed Jan 19, 2005 1:08 pm
by chillee
Well I tried installing a short ram intake, but I didn't have the necessary hardware to finish the job (I needed 2 longer screws for that sensor thingy cuz I just got the intake manifold from a friend). Anyways, I installed the factory intake back in and now the CEL (check engine light) came on and my Vibe is not idling like it used to (Idles between 1200-1400 back and forth). I checked the air lines and didn't notice anything wrong. Any suggestions?
Re: Tried installing short ram intake... (chillee)
Posted: Wed Jan 19, 2005 1:09 pm
Probably messed up your MAF sensor...Take it out, make sure it's clean and doesn't look bent out of shape or anything...
Posted: Wed Jan 19, 2005 11:08 pm
by nismo
I thought that the MAF sensor came with it's own screws. That's what I used. Mine works great . Inder
Re: Tried installing short ram intake... (TRD4reel)
Posted: Thu Jan 20, 2005 12:20 am
by Mavrik
mine worked fine also, used them.but your idle issue, may be a vac prob possibly or as mentioned a MAF problem. However the usual symptoms of a bad MAF is idles fine but you can't rev past 2800rpm.
Posted: Thu Jan 20, 2005 3:43 pm
by chillee
Thanks everyone...I'm still trying to figure it out...it's still acting up...probably gotta take it to a shop
Posted: Thu Jan 20, 2005 9:19 pm
by MadBill
Well at least with the stock intake back in place, you can play the warranty card...
Re: Tried installing short ram intake... (Mavrik)
Posted: Thu Jan 20, 2005 9:39 pm
by PhillyVibeGT
Quote, originally posted by Mavrik »mine worked fine also, used them.but your idle issue, may be a vac prob possibly or as mentioned a MAF problem. However the usual symptoms of a bad MAF is idles fine but you can't rev past 2800rpm. I had that problem when I first installed my CAI, make sure you put the hoses back in the proper spots if not it will rev back and forth like you said. Good Luck!
Posted: Sat Jan 29, 2005 5:25 am
by chillee
Well I took it to the shop and it took them awhile to figure it out. They replaced the intake gasket and now it works fine. Hopefully it will stay like that!
