kit -screwed or taped?
Posted: Fri Jan 14, 2005 2:09 am
by 2-Flush
Hey guys this is my first time in a discussion forum so hopefully I do this right. Does anyone know how the vibe bodykit that pontiac sells is attached to the car? Is it screwed in or is it attached with 2 sided tape? I saw one a few weeks ago with the kit on and I was really disappointed. Seemed like it didn't fit very well (typical gm quality) and I saw tape already seperating from the kit and body. I was thinking it was a poor install job, but if it's just taped on I think I'll pass. Also - would the spoilers be drilled into the car and could this lead to leaks? Thanks in advance to anyone who replies.
Re: kit -screwed or taped? (2-Flush)
Posted: Fri Jan 14, 2005 2:30 am
by damronjr
Quote, originally posted by 2-Flush »Hey guys this is my first time in a discussion forum so hopefully I do this right. Does anyone know how the vibe bodykit that pontiac sells is attached to the car? Is it screwed in or is it attached with 2 sided tape? I saw one a few weeks ago with the kit on and I was really disappointed. Seemed like it didn't fit very well (typical gm quality) and I saw tape already seperating from the kit and body. I was thinking it was a poor install job, but if it's just taped on I think I'll pass. Also - would the spoilers be drilled into the car and could this lead to leaks? Thanks in advance to anyone who replies.As per the instructions I received with my midgate spoiler it is drilled into the rear hatch with 4 screws, but if installed properly, has a seal that surrounds those 4 screws so there should be no possibility for leaks. As for the top spoiler, I do not have one and am not sure. Same with the GM bodykit. I know some folks on here have that, so someone should be able to help there, but I should think it is bolted on using pre-existing bolts.
