Engine Whistle at High RPM's
Posted: Thu Jan 13, 2005 7:18 am
by BlueCrush
Since I bought my Vibe I have been getting a whistling sound from the engine starting at 5500 RPM's all the way up the the limit of 6200 RPM's. I was thinking it was just a warning signal to let you know you are getting close to the Rev Limit. Has anyone else experienced a whistling sound?
Posted: Thu Jan 13, 2005 1:20 pm
by Lucky317
wheres the whistle coming from and how loud s it?? could be a belt issue. It's definitely NOT a rev limit warning.
Re: (Lucky317)
Posted: Fri Jan 14, 2005 7:50 am
by BlueCrush
It's coming from the engine compartment and I can hear it pretty good over my Cosmo short ram intake and Dynomax Muffler. I am also finding it doesn't happen everytime. I will have the dealer look into it at my next oil change.
Re: (BlueCrush)
Posted: Fri Jan 14, 2005 8:20 am
by nismo
Yes, you may want to have your belts checked. That may be your problem.Inder
Posted: Fri Jan 14, 2005 1:16 pm
by kostby
Could also be a vacuum leak (e.g. the intake manifold gasket), but if that's what it is, I don't know why it would not be present all the time.
Re: (kostby)
Posted: Fri Jan 14, 2005 1:19 pm
by BlueCrush
I will have the dealer check the belt and manifold gasket. Any other suggestions?
Posted: Fri Jan 14, 2005 4:29 pm
by Lucky317
if it was that bad of a vacuum leak you'd have other problems like the car not wanting to run lol to check yourself spray a lil brake kleen around the TB and manifold. if the idle jumps at any point then you have a leak
