intakes & warranties
Posted: Wed Jan 12, 2005 12:06 am
by cieglo
I'm a new Vibe owner, 1 week as of yesterday, and I love my GT. It's a 2003 and is great fun to drive. But enough is never enough. I'mm looking at K&N, Injen and Bomz intake systems. Does installing one these have any factory warranty implications?
Re: intakes & warranties (cieglo)
Posted: Wed Jan 12, 2005 12:17 am
by PhillyVibeGT
No, there are no warranty implications, there is a federal act that allows aftermarket bolt-on products without voiding the warranty. If you go to injen's website they have it posted. Good Luck! Enjoy your GT.
Posted: Wed Jan 12, 2005 12:22 am
by Mr. Poopypants
Congrats!! and Welcome to GenVibe. I wish I had lift
Posted: Wed Jan 12, 2005 1:23 am
by nismo
Welcome to the forums . Well, depends on how much of your warranty is left. I mean, if you're really concerned about your warranty being voided, I would just recommend getting a K&N filter for now just to be on the safe side. And when your warranty is up, get whatever performance parts you want. But if you don't have much warranty left anyways, I would just recommend getting the Injen. It's not going to hurt your car in any way. So, I would say go for it.
Re: intakes & warranties (TRD4reel)
Posted: Wed Jan 12, 2005 2:02 am
by Raven
Put on a CAI and if you need warranty work done and your worried about it, put the airbox back on before you bring it in. It only takes about an hour. You'll feel and hear the power gain.
Re: intakes & warranties (Sunny)
Posted: Wed Jan 12, 2005 2:04 am
by nismo
Quote, originally posted by Sunny »Put on a CAI and if you need warranty work done and your worried about it, put the airbox back on before you bring it in. It only takes about an hour. You'll feel and hear the power gain.I agree
Posted: Wed Jan 12, 2005 9:23 pm
by cieglo
Thanks for the info!
Posted: Wed Jan 12, 2005 9:53 pm
by Mavrik
Quote, originally posted by Sunny »Put on a CAI and if you need warranty work done and your worried about it, put the airbox back on before you bring it in. It only takes about an hour. You'll feel and hear the power gain.Thats what I did when my MAF went south after the first install of my Injen CAI haha.
Posted: Wed Jan 12, 2005 10:03 pm
by kostby
Welcome to the Encyclopedia of Vibe!Yeah, it seems that the Mass Air Flow thingie goes south shortly after a lot of CAI installs. Mere coincidence or evil plot by GM/Toyota?
Re: (kostby)
Posted: Wed Jan 12, 2005 10:24 pm
by Mavrik
I think it has to do with a volt spike in the system maybe... Next time I'll keep it disconnected when I install the battery, then hook it up afterwards. Its just really weird...
Posted: Thu Jan 13, 2005 3:13 am
by knoxville2013
after i put on the cosmo intake, if i dont let the car warm up for about 5-10 minutes then it will never rev past 4500. but after a few minutes it will go the full 6200 or however far it goes. im not sure if it has to do with the MAF sensor..but does this happen to anyone else?
Re: (knoxville2013)
Posted: Thu Jan 13, 2005 3:19 am
by nismo
That rev limiter kickc in so you don't melt the motor together. We have an aluminum block, so if it heats up too fast then the motor can melt together. That rev limiter has been there even before you do any mods to it. So, yeah, that's perfectly normal.Inder
Posted: Thu Jan 13, 2005 3:23 am
by Lucky317
must be a vibe thing cause the celicas don't have a problem with the maf. we have found that it gets dirty and can cause some minor issues over time. but al you have to do is remove it, spray a lil cleaner and it's back to new.
Posted: Thu Jan 13, 2005 3:32 am
by knoxville2013
ok thanks, that makes sense...i guess i have just been noticing the revs more now cause of how much louder it is. thanks though
Posted: Thu Jan 13, 2005 3:53 am
by wicked1981
Congrats and welcome to the forum.
Re: intakes & warranties (wicked1981)
Posted: Sun Feb 06, 2005 4:36 am
by cieglo
Thanks. Everyone posts a lot of good info and ahven't come across any bad apples yet...this is a nice place to visit.
Posted: Sun Feb 06, 2005 10:14 pm
by goodvibe
The often MAFs go south because they get a light coating of oil from the filters. Don't over oil and let them sit out for a day before installation. If it happens, pull the MAF and spray it clean with some carb cleaner. You probably don't need the dealer. It happened to me with a new drop in and it cleaned right up. It never happened again but I decided to sell the filter after a few thousand miles. If you get a CAI, you'll have less power below 3k or a bit higher on the GT and gain alot at the top.
Posted: Mon Feb 07, 2005 3:03 am
by MoonDogg
Welcome and good pick on the GT... gotta love the lift... good luck with the intake and I am sure you will get all your questions answered here...
Re: intakes & warranties (PhillyVibeGT)
Posted: Mon Feb 07, 2005 11:00 am
Quote, originally posted by PhillyVibeGT »No, there are no warranty implications, there is a federal act that allows aftermarket bolt-on products without voiding the warranty. If you go to injen's website they have it posted. Good Luck! Enjoy your GT.Not ENTIRELY true.They can't void your warranty just for having installed the intake.But if somehow, they can prove, damage was caused as a result of that add-on product, then yes, they can deny you warranty coverage.For example. Let's say there was a hole in your intake filter you weren't aware of. Somehow, a small pebble gets into that, and goes into your engine, and "blows it up." You, my friend, are SOL, because that product was (A) not GM approved and (B) was at fault when that stone got sucked in.However, if, let's say, your power window motor stops working. They can't tell you your warranty is null and void just because of the intake. The problem has to be proven to be a direct result of that modification.
