My window Trim is coming off
Posted: Mon Jan 03, 2005 11:13 pm
by newbalance336
the trim on the outside of the door is loose! i could pull it completly off if i wanted to. WHat should i use on it. Do i need new trim or jsut a little tlc
Re: My window Trim is coming off (newbalance336)
Posted: Mon Jan 03, 2005 11:32 pm
by nismo
The trim? Are you talking about the weatherstriping that is right above the door handle? If so, mine came off an I took to the dealer and they took care of it.Inder
Posted: Wed Sep 06, 2006 12:40 am
by ZubenElGenubi
Reuse and recycle, I always say.My weatherstripping around the top of the driver and passenger front windows has expanded and is starting to buckle. I've got 37K on this car; you think GM will help replace it? Anyone else had this problem? I'm suspecting that the heat has gotten to it somehow, but there's no obvious damage to it...just looks funny.
Re: My window Trim is coming off (ZubenElGenubi)
Posted: Wed Sep 06, 2006 1:02 am
by Mrizzle05
my passenger weatherstripping above the door handle has been peeling and leaving plastic like residue on the window since i got the car... im at like 27K already... so i need to take mine in, soon.If its any part and your still under warranty take it to the dealer. if out of warranty, see if they will still help you, or see what the trim costs and replace it.Other then that not much else if you can pretty much rip it off.
Re: My window Trim is coming off (Mrizzle05)
Posted: Wed Sep 06, 2006 1:39 am
by ZubenElGenubi
Quote, originally posted by Mrizzle05 »Other then that not much else if you can pretty much rip it off.Yep, I could probably pull it out easily. I'll check with a dealer today and see what they can do.
