Check Engine Light
Posted: Wed Dec 29, 2004 3:19 am
by habnar
I had the check engine light come on one day after I started a drove my Vibe for about 5 miles. The dealer checked it and said the gas cap was loose. (it was the first thing I checked) Of course, the light came on again the next day after the second start of the day. Now, they say it is a leak in my EVAP vent solenoid valve. Has anyone else had a similiar problem?2004 Vibe FWD, AUTO.
Re: Check Engine Light (habnar)
Posted: Wed Dec 29, 2004 3:42 am
by Mavrik
Not a to uncommon problem on GM vehicles, nothing serious and since they fixed it, your good to go. I've never had that problem with any GM vehicle I ever owned and thats all I have owned, but a few here and there have had that concern with a sticking EVAP valve letting to much pressure out of the tank.
Posted: Wed Dec 29, 2004 3:45 am
by dsegundo
Maybe I'll alert the dealership to this....of course it's the least of my problems.
Posted: Wed Dec 29, 2004 3:49 am
by habnar
Thanks for the feed back...The car is still at the dealer, so, the jury is still out on the positive fix...I'll report back in a week if the CEL hasn't come on.
Re: (dsegundo)
by Mavrik
well I don't think it will be related to the engine issue with yours. this concern won't change the way the vehicle runs, its mainly emissions control systems.
Posted: Wed Dec 29, 2004 4:32 am
by scherry2
yep, i did and they replaced the solenoid no problems now.
Posted: Wed Dec 29, 2004 12:16 pm
by simon
I had the same problem. Took them a while to figure out what the problem was, as it was the first time they'd seen it on a vibe, this was in Jan '03. Not had a problem with the fuel system since - except a frozen fuel cap door. Cured by levering on door with key while jiggling the lever!
Re: (simon)
Posted: Wed Dec 29, 2004 1:54 pm
by ragingfish
Quote, originally posted by simon »a frozen fuel cap door. Cured by levering on door with key while jiggling the lever!Hot water, if available, works wonders!
Re: (ragingfish)
Posted: Wed Dec 29, 2004 8:03 pm
by Mavrik
Quote, originally posted by ragingfish »Hot water, if available, works wonders! I've had to use my key while pulling the lever to, and hot water usually isn't on a ready supply down at the self serve gas pumps.
Posted: Wed Jan 05, 2005 4:24 am
by habnar
Thanks for all the feed back... It's been a week now and no check engine light. Hopefully, it's a good fix.
Posted: Mon Jan 17, 2005 10:57 am
by Raivis
i have had the same problem word for word try telling them to replace the vapor canister and clean out the vent and purge lines. if your dealership needs more info have them call Mclean (the blue team leader) at suttle motor corp. at 757-886-1800. that finally fixed mine let me know how it goes. they took five times to finnally fix my vibe gt
Re: Check Engine Light (Raivis)
Posted: Thu Jan 20, 2005 2:48 am
by habnar
It has been good for 3 weeks now. The solenoid they replaced must have fixed it.
