Top Tier Gasoline...
Posted: Tue Dec 28, 2004 11:39 am
by ToolGuy
Info - Top Tier Detergent Gasoline (Deposits, Fuel Economy, No Start, Power Performance, Stall Concerns) #04-06-04-047C - (Dec 14, 2004)Top Tier Detergent Gasoline (Deposits, Fuel Economy, No Start, Power, Performance, Stall Concerns)2005 and Prior All General Motors Passenger Cars and Trucks (U.S. Only)2005 and All Prior Saturn Vehicles2003-2005 HUMMER H2A new class of gasoline, called Top Tier Detergent Gasoline, is appearing at retail stations of some fuel marketers. This gasoline meets detergency standards developed by four automotive companies. A description of the concept and benefits of Top Tier is provided in the following question and answer section.Gasoline Brands That Currently Meet Top Tier Detergent Gasoline StandardsAs of December 8, 2004, the following gasoline brands meet the Top Tier Detergent Gasoline Standards:• Chevron Chevron has markets in 29 states in the West, Southwest and South, as well as in Alaska and Hawaii. ALL grades of Chevron with Techron gasoline meet Top Tier Detergent Gasoline Standards. • QuikTrip (not to be confused with Kwik Trip) QuikTrip operates convenience stores and travel centers in a number of metropolitan areas: • Tulsa, OK • Springfield, MO • Kansas City, MO and Kansas City, KS • Wichita, KS • Des Moines, IA • Omaha, NE • St. Louis, MO and St. Louis, IL • Atlanta, GA • Dallas-Ft. Worth, TX • Phoenix, AZ • Bartlesville, OK • Miami, OK • Vinita, OK • Columbia, MO • Conoco has over 4,000 stations located in 33 states. • Phillips 66 has locations in 32 states across the nation. • 76 has over 2,700 stations located throughout the country. • Shell Shell Oil Products has a network of nearly 7,000 branded gasoline stations in the Western United States. Shell Oil Company markets branded products through more than 10,000 stations in the Eastern and Southern United States. • Entec Stations offer gasoline through stations located in the greater Montgomery, Alabama area. What is Top Tier Detergent Gasoline?Top Tier Detergent Gasoline is a new class of gasoline with enhanced detergency. It meets new, voluntary deposit control standards developed by four automotive companies that exceed the detergent requirements imposed by the EPA.Where Can Top Tier Detergent Gasoline Be Purchased?The Top Tier program began on May 3, 2004. Some fuel marketers have already joined and have introduced Top Tier Detergent Gasoline. This is a voluntary program and not all fuel marketers will offer this product. Once fuel marketers make public announcements, they will appear on a list of brands that meet the Top Tier standards.Who developed Top Tier Detergent Gasoline standards?Top Tier Detergent Gasoline standards were developed by four automotive companies: BMW, General Motors, Honda and Toyota.Why was Top Tier Detergent Gasoline developed?Top Tier Detergent Gasoline was developed to increase the level of detergent additive in gasoline. The EPA requires that all gasoline sold in the U.S. contain a detergent additive. However, the requirement is minimal and in many cases, is not sufficient to keep engines clean. In order to meet Top Tier Detergent Gasoline standards, a higher level of detergent is needed than what is required by the EPA. Also, Top Tier was developed to give fuel marketers the opportunity to differentiate their product.Why did the four automotive companies join together to develop Top Tier?All four corporations recognized the benefits to both the vehicle and the consumer. Also, joining together emphasized that low detergency is an issue of concern to several automotive companies.What are the benefits of Top Tier Detergent Gasoline?Top Tier Detergent Gasoline will help keep engines cleaner than gasoline containing the "Lowest Additive Concentration" set by the EPA. Clean engines help provide optimal fuel economy and performance and reduced emissions. Also, use of Top Tier Detergent Gasoline will help reduce deposit related concerns.Who should use Top Tier Detergent Gasoline?All vehicles will benefit from using Top Tier Detergent Gasoline over gasoline containing the "Lowest Additive Concentration" set by the EPA. Those vehicles that have experienced deposit related concerns may especially benefit from use of Top Tier Detergent Gasoline.
Posted: Tue Dec 28, 2004 11:36 pm
by Jahntassa
Nice to know! I had heard QuikTrip throwing around the Top Tier stuff..but wasn't quite sure what it was all about..
Posted: Thu Dec 30, 2004 9:51 pm
by cdFxer
Hmmm. All of our gas up here comes from St Louis. Actually from the same fueling depots the trucks fill from to fill the St. Louis stations (or at least some of them). Hopefully we will get to see some of this in our area.
