Alternative method for mounting a FRONT license plate
Posted: Mon Dec 27, 2004 6:31 am
by Psychobroker
Per the title, does anyone have any recommendations in alternative mounting methods for a front license plate? I don't like the GM mount, and am NOT willing to drill through the new bodykit once it's installed. Magnets? Some form of bracket? I guess I could zip tie it to my grilles, but that would look aweful. Oh, and I COULD go back to the GM mount for now, had I not lost parts of it Anyway, I'm just looking for any suggestions at this point. I drive right by LAX (airport) from home to work, and the LAX cops have NOTHING better to do than stop people for crap like not having a front bumper-mounted plate. I've only been stopped once, but I've seen at least 3 other people stopped for the same reason. Thanks for your suggestions.PS double-sided tape does NOT work
Re: Alternative method for mounting a FRONT license plate (Psychobroker)
Posted: Mon Dec 27, 2004 6:40 am
by nismo
You could get a customizing shop to make like an enclosure for the license plate. But I would not recommend doing that. Too much $. Unless you have the spare cash laying around.Inder
Posted: Mon Dec 27, 2004 6:48 am
by damronjr
Took mine off as well. Correct me if I'm wrong, but as long as it is visible from the front of the vehicle it is fine, right? I ust took mine off and put in on the passenger side visor under the strap so you can still see it from the front of the vehicle. I haven't gotten pulled over down here, but then I was watching on eday and saw like 10 cars that didn't even have any visible front plate, and I guess they weren't worried, so not sure about that.
Re: Alternative method for mounting a FRONT license plate (damronjr)
Posted: Mon Dec 27, 2004 6:57 am
by nismo
Why is this is a law? To have a front license plate. Us in MI don't have to have the front license plates. Just wondering.Inder
Re: Alternative method for mounting a FRONT license plate (TRD4reel)
Posted: Mon Dec 27, 2004 6:59 am
by damronjr
Quote, originally posted by TRD4reel »Why is this is a law? To have a front license plate. Us in MI don't have to have the front license plates. Just wondering.InderCA and various other states require a front and rear license plate.
Posted: Mon Dec 27, 2004 7:06 am
by nismo
It's just that. I've seen em, but why?Inder
Posted: Mon Dec 27, 2004 7:23 am
by damronjr
Police usage I assume.
Posted: Mon Dec 27, 2004 7:34 am
by Psychobroker
CA law REQUIRES that you not only have both a front & rear license plate, but it MUST be mounted ON your bumper....!@##% CA laws and cops with nothing better to do! I have it in my dash, clearly visible, but that didn't matter to the cop that pulled me over.Jason, please sign this petition when you get the chance: http://www.petitiononline.com/....html
Posted: Mon Dec 27, 2004 7:45 am
by damronjr
Quote, originally posted by Psychobroker »CA law REQUIRES that you not only have both a front & rear license plate, but it MUST be mounted ON your bumper....!@##% CA laws and cops with nothing better to do! I have it in my dash, clearly visible, but that didn't matter to the cop that pulled me over.Didn't know all that! oh well, guess I'll keep getting lucky as long as I can since it's only a fix-it ticket anyways!Quote, originally posted by Psychobroker »Jason, please sign this petition when you get the chance: http://www.petitiononline.com/....htmlDone!
Posted: Mon Dec 27, 2004 8:24 am
by Mase
This SoCal Matrix Owner screwed it to the underside of the front bumper and bent it to sit flat against the lower grill. Not sure if this can be done on the Vibe's front end though.
Re: Alternative method for mounting a FRONT license plate (Mase)
Posted: Mon Dec 27, 2004 8:28 am
by Psychobroker
Thanks Mase, I can probably do that and zip-tie it snugly to my lower grille.
Posted: Mon Dec 27, 2004 8:31 am
by damronjr
Whatever works, huh!
Posted: Mon Dec 27, 2004 8:34 am
by Psychobroker
Quote, originally posted by damronjr »Whatever works, huh!Yeah, whatever to get the cops focused on REAL criminals
Posted: Mon Dec 27, 2004 8:45 am
by MadBill
Here's where I mounted mine (after I chickened out about running without one qfter six months...):
Posted: Mon Dec 27, 2004 9:49 am
by Psychovibe
Christian,When we get the test pieces back I'll see if I can make a bracket that screws to the inner structure and doesn't touch the bumper itself. It shouldn't be too long before we get it back and I'll see what I can whip up that is still show worthy.Chris
Re: Alternative method for mounting a FRONT license plate (Psychovibe)
Posted: Mon Dec 27, 2004 10:00 am
by damronjr
Quote, originally posted by Psychovibe »Christian,When we get the test pieces back I'll see if I can make a bracket that screws to the inner structure and doesn't touch the bumper itself. It shouldn't be too long before we get it back and I'll see what I can whip up that is still show worthy.ChrisHey, sounds good!
Posted: Mon Dec 27, 2004 11:09 am
by simon
Check this thread out:http://forums.genvibe.com/zerothread?id=11581Madbill has a link to a picture of his Vibe with the licence plate bolted on to the lower grill.
Posted: Mon Dec 27, 2004 1:57 pm
by kostby
Does the CA law require THE California official license plate on the front, or just the number/letter combination? Maybe you could use the wide, thin 'European' style plate(s) with your official California number/letter designation?
Re: (kostby)
Posted: Wed Dec 29, 2004 3:30 am
by Psychobroker
Quote, originally posted by kostby »Does the CA law require THE California official license plate on the front, or just the number/letter combination? Maybe you could use the wide, thin 'European' style plate(s) with your official California number/letter designation?Yes, CA requires a California plate on the front. To the best of my knowledge, no euro plates allowed.
Posted: Thu Dec 30, 2004 2:05 am
by Psychobroker
Quote, originally posted by Psychovibe »Christian,When we get the test pieces back I'll see if I can make a bracket that screws to the inner structure and doesn't touch the bumper itself. It shouldn't be too long before we get it back and I'll see what I can whip up that is still show worthy.ChrisI missed your post at first, but wanted to thank you Chris. That would be awesome if you could do it. For now, I've used a couple zip-ties to my lower grille. Doesn't look too pretty, but gets the job done.
