Indicator light for auto. gear shifter
Posted: Fri Dec 17, 2004 12:39 am
by simon
Does anyone know how to replace the light that illuminates which gear you're in on the gear shifter?Simon
Re: Indicator light for auto. gear shifter (simon)
Posted: Fri Dec 17, 2004 2:54 am
by ToolGuy
This process and pic should help...Remove the manual transmission shift knob, if equipped. Remove the center A/C control knob (3). Remove the screw (1). Using a taped flat bladed tool, gently pry and release the retaining clips which secure the front floor console trim plate (2) to the front floor console assembly. Disconnect the following components: The 2 cigar lighter electrical connectors The accessory power receptacle electrical connectors Remove the cigar lighter assembly, if necessary. Refer to Cigar Lighter Replacement . Remove the accessory power receptacle, if necessary. Refer to Power Outlet Receptacle Replacement in Power Outlets.
Posted: Fri Dec 17, 2004 2:57 am
by ragingfish
Well, there's only a backlit gear indicator on the auto.And I've yet to successfully remove the auto shift knob...And getting under the plastic then is still a pain.Your best bet is to take it to the dealer..I've ripped apart just about every square inch of the interior of this car, but have yet to be able to figure out how to remove the shifter trim...
Re: (ragingfish)
Posted: Fri Dec 17, 2004 3:27 am
by ToolGuy
Quote, originally posted by ragingfish »Well, there's only a backlit gear indicator on the auto.Is'nt that the bulb he is trying to replace?Have you bought a service manual for yours?
Re: (MiVibe-ToolGuy)
Posted: Fri Dec 17, 2004 3:51 am
by ragingfish
Quote, originally posted by MiVibe-ToolGuy »Is'nt that the bulb he is trying to replace?Yeah, I said that cause your instructions said remove the manual shift knob.Quote »Have you bought a service manual for yours?Yuppers, and it's still a b*tch to do.
Re: (ragingfish)
Posted: Fri Dec 17, 2004 4:01 am
by ToolGuy
[QUOTE=ragingfish]Yeah, I said that cause your instructions said remove the manual shift knob./QUOTE]Right and that was taken directly from the GM Serv Manuals and it is the procedure for the trim removal auto/mamual. The auto trans bulb replacement is either buried in somewhere or not in at all. Just a quick look is all I did and came up with that. Hopefully that will get him on the right track. Dealer LOL! At probably $60-80 an hour that would be an expensive bulb replacement. 300% markup on the bulb too... Not flameing you but the dlr rates.
Re: Indicator light for auto. gear shifter (MiVibe-ToolGuy)
Posted: Fri Dec 17, 2004 5:48 am
by simon
Thanks for the info.It looks like a job that will probably not be done until the summer (if then!) as I'll be outside for a long time with numb fingers up here in Canada.Why wouldn't they make the thin plastic piece above the PRND21 removable and then the whole job could be done in 5 minutes.Simon
Posted: Fri Dec 17, 2004 6:03 am
by nismo
Hey, I took apart that piece. Here's the link to the walk through:
http://forums.genvibe.com/zerothread?id=13822Under that, that's where you can change the color of the bulb.Inder
Re: Indicator light for auto. gear shifter (TRD4reel)
Posted: Sat Dec 18, 2004 8:01 am
by simon
Brilliant :-)Thanks a lot. Great pictures. That certainly beats the hell out of the GM method!
Posted: Sat Dec 18, 2004 8:02 am
by nismo
haha. What was the GM method?Inder
