Anyone considered an Ecotec?
Posted: Thu Dec 09, 2004 7:11 am
by Turbo5Speed
For those who are unfamiliar with it, the Ecotec is the new engine GM is trying to push which is supposed to be the new age version of the small block V8 (Except that it's a 4 cyl.) which means they'll have loads of AM parts for it. The engine is used in the Saturn Ion Redline, new Saabs, the new Chevy Cobalt, and other cars. If it would fit properly (The Vibe is a Toyota, even through it's wrapped in Pontiac symbols) it would allow the Vibe to be a heck of a tuner car. It'd most likely be able to do 0-60 in 5 secs if built with the right components.Any thoughts?
Re: Anyone considered an Ecotec? (Turbo5Speed)
Posted: Thu Dec 09, 2004 7:15 am
by nismo
From what I have heard, the Ecotec line has not been as reliable as could be. I have a buddy with a Z24 with a Ecotec in it and regrets everyday he has the car.Inder
Re: Anyone considered an Ecotec? (TRD4reel)
Posted: Thu Dec 09, 2004 7:19 am
by Turbo5Speed
I'm not a huge fan on Cavaliers myself, or a Saturn fan for that matter. But I can't deny the potential that the Saturn Ion Redline has, 0-60 in 5.9 seconds. GM did a 309 mph run on the salt flats with a 4 cylinder Ecotec engine built from parts that are available (or will shortly be) from GM Goodwrench Parts. Even if it it wouldn't be the best idea for a swap, it may still make a good discussion point and bring up some better potentials (Since it's a toyota, what about the VVT-i Lexus engines?)
Posted: Thu Dec 09, 2004 7:27 am
Ecotec isn't very new...it was one of the engine options when I was shopping for my Sunfire back in 01...
Posted: Thu Dec 09, 2004 7:31 am
by damronjr
Just consider this, Celicas run the exact same engines we do and tey get modded to hell! Pick up any tuner mad and you will find at least 1 Celica in there. I saw a GTS in a mag I got the other day with the 2ZZ with a A'PEX turbo! Guess what that means?!? Should work with the GT?!? I'm sure other Celica GT's have been done as well so there has to be stuff out there, but finding it under VIBE is not a likely place to look. Maybe we should start searching for Celica parts and see what we come up with. I know some are fitted to the car itself, but that is just a matter of spacing a such. It's gotta be worth a try!
Re: Anyone considered an Ecotec? (damronjr)
Posted: Thu Dec 09, 2004 7:41 am
by nismo
Well, for internal work. You could go to http://www.monkeywrenchracing.com . They have many parts for internals for the 2zz and the 1zz. I think it would wise to check these out as well.Inder
Posted: Thu Dec 09, 2004 9:38 am
by Turbo5Speed
Celica's still have some differences in them, even though the Celica GT-s engine is the 1.8l VVTL-i engine found in the Vibe GT and Matrix XRS. I beliece their computer is different, for one thing, although if you had your computer custom programmed by Jim Wolfe, that area wouldn't be a problem at all.
Posted: Thu Dec 09, 2004 12:23 pm
by Jahntassa
Yeah, I love the 2.2L Ecotec in my in-law's Cavalier LS. That thing sucks, especially next to the 2001 Grand Am SE, which I know puts out around 130 Hp, and it's a smaller engine, if I remember correctly..
Re: (Jahntassa)
Posted: Thu Dec 09, 2004 10:04 pm
by Turbo5Speed
Well, again it's a cavalier Anyone test-rode in an Ion Redline yet? Or in one of the 2.0 DOHC Turbo engines putting out 210 hp? They're pretty responsive for being stock.
Re: (Turbo5Speed)
Posted: Fri Dec 10, 2004 1:30 am
by nismo
Are they runnin a cable throttle? If they're runnin a cable, they should be quite nice. Electronic, I wouldn't recommend it.Inder
Re: (TRD4reel)
Posted: Thu Dec 30, 2004 10:52 am
by clwcrw
I owned a 2002 Cavalier LS Sport, 5 spd that had the Ecotec, for about 15000 miles. I thought it was a pretty solid engine. 140 HP, 150 FT/LB of torque. It wasn't the quickest thing in the world. I loved the oil filter location. It was on TOP of the engine! Made for very easy oil changes. The best part is that on one trip from Southwest Michigan to Columbus, OH and back, I got 41 mpg! Chris
Re: (clwcrw)
Posted: Thu Dec 30, 2004 10:53 am
Quote, originally posted by clwcrw »I loved the oil filter location. It was on TOP of the engine! Made for very easy oil changes.That's freakin cool! If you unscrewed the filter, wouldn't oil spill all over the engine though?
Re: (ragingfish)
Posted: Thu Dec 30, 2004 11:20 am
by clwcrw
No, there was a cap with a small diameter spring that put pressure on the filter element. There was a ressed (spelling?) area built into the block where the filter element rested. There would be a small pool of oil in the bottom of the ressessed area, but no oil that would run out. By far the coolest thing I have ever seen on a motor!As a bit of trivia, the Ecotec first appeared in the Saturn brand, as far back as 2000. Chris
