Need wiring diagram for M&T cd player!
Posted: Mon Nov 29, 2004 5:54 am
by damronjr
I want to run another amplifier off of the M&T amp under the passenger seat to power subs. I plan to run new power and ground wires, but I wanted to use the remote and audio input wires from the radio from the wires that run into the M&T amp. Anyone know which wires these are and if this is possible? I don't see how it would be a problem, but maybe someone knows something I don't.Oh, BTW, I tried looking through the other threads regarding this, but couldn't seem to come up with the information I was looking for. Any help would be greatly appreciated.
Re: Need wiring diagram for M&T cd player! (damronjr)
Posted: Mon Nov 29, 2004 8:16 am
Check your IM.
Re: Need wiring diagram for M&T cd player! (ragingfish)
Posted: Mon Nov 29, 2004 8:21 am
by damronjr
doesn't work from here at home for some reason. can you email me at
jason_damron@yahoo.com?
Posted: Mon Nov 29, 2004 8:58 am
Posted: Mon Nov 29, 2004 9:35 am
by damronjr
So I'm gathering from the schematics that all of the wires that are "audio inputs" are essentially the same as the RCA's from the back of an aftermarket HU? If this is the case, is it possible to run these wires to an aftermarket amp since they only have RCA input plugs?
Posted: Mon Nov 29, 2004 9:52 am
by scherry2
check out this thread
http://forums.genvibe.com/zerothread?id=13072 jahntassa gave me the heads up on how to do it. hope this helps. I just spliced in to the rear speaker wires with the converter he is talking about
Posted: Mon Nov 29, 2004 2:52 pm
by Jahntassa
Yeah, it's still a speaker-level signal going to the M&T amp I believe. It's just that the amp and the stereo talk to each other, so the M&T amp can handle the power input. Makes it cheaper to not make specially designed radios..
