Anyone have rear suspension squeaks?
Posted: Sun Nov 28, 2004 8:51 am
by P POPPR
We have a squeak that we hear when the driver gets out of the car on a flat surface. Sounds like it's coming from the rear suspension. Kind of a rubber squeak. We had it at the dealer and naturally it didn't squeak.
Re: Anyone have rear suspension squeaks? (P POPPR)
Posted: Sun Nov 28, 2004 9:03 am
by nismo
Yeah man. It started squeaking this July when I took my car on a trip to the east coast.Inder
Re: Anyone have rear suspension squeaks? (TRD4reel)
Posted: Sun Nov 28, 2004 9:21 am
by P POPPR
Do you know what causes the squeak?
Posted: Sun Nov 28, 2004 10:54 am
by nismo
Long period of traveling on the car. How much do you drive it when you do? At least, this is my problem.Inder
Posted: Sun Nov 28, 2004 11:28 am
by P POPPR
30 minutes
Posted: Sun Nov 28, 2004 11:31 am
by nismo
Yeah, that'll prolly do it. That happens to me sometimes.Inder
Posted: Sun Nov 28, 2004 8:42 pm
by ColonelPanic
Could be a bushing somewhere causing the squeak... Haven't had it happen on the Vibe myself, but it did happen on the last car (had 2 sets of rear sway bar bushings installed on that thing...) Not sure, may be something to look into.
Posted: Mon Nov 29, 2004 11:08 am
by blake31
yes, i hear this on mine all the time
Posted: Fri Dec 03, 2004 3:17 am
by 5lbsofswisscheese
My first Vibe did that after a while. I never did manage to isolate the source of the sound. I'll try a little harder if it happens to this one.
Posted: Tue Jan 04, 2005 7:54 am
by P POPPR
As an update, I had the car at the dealer today for the squeak. I''ll post again with a report if this fixes the problem, but here's what they did."Exhaust squeaking at pivot points. Removed exhaust-lubed front donut-disassembled rear flex joint and lubed all hanger points"
Posted: Wed Jan 05, 2005 3:24 am
by ColonelPanic
That sounds like a good possibility- do keep us posted!
Re: Anyone have rear suspension squeaks? (ColonelPanic)
Posted: Sun Feb 06, 2005 3:58 am
by P POPPR
Still got the squeak. Maybe the third time is the charm.
Posted: Sun Feb 06, 2005 4:04 am
by nismo
Well, mine are more like a creak actually. Not a sweak. But now, whenever I take left turns I hear this ping sound coming from the back right strut. I've narrowed it down to the suspension. This also happens on rough terrain. Rough terrain meaning Detroit roads.
Posted: Sun Feb 06, 2005 4:16 am
by ragingfish
A ping is likely a rock kicking up and hitting your exhaust...
Re: (ragingfish)
Posted: Sun Feb 06, 2005 1:29 pm
by nismo
Naw man, it happens all the time. I'm just waitin for it one day when I hear ping crush! My back right strut just falls. Inder
Posted: Mon Feb 07, 2005 1:35 am
by Herb
Quote, originally posted by P POPPR »We have a squeak that we hear when the driver gets out of the car on a flat surface. Sounds like it's coming from the rear suspension. Kind of a rubber squeak. We had it at the dealer and naturally it didn't squeak.I'm getting a squeak as well. I went to a dealer and was told that it was caused by the parking brake. As soon as I disengaged it, the squeaking stopped.
Re: Anyone have rear suspension squeaks? (Herb)
Posted: Mon Feb 07, 2005 3:10 am
by nismo
So you have no e-brake? That's not good man.
Posted: Mon Feb 07, 2005 4:08 am
by Herb
Quote, originally posted by TRD4reel »So you have no e-brake? That's not good man.I got e-brake, but when it's applied it squeaks.The report states:"Checked for sqeak from rear as described, appears only to when emerg brake is applied. Probably normal due to sight shoe movement reaction against backing plate."Dealer told me that it's normal and it's not something that needs to be worked on.
Posted: Mon Feb 07, 2005 5:30 am
by P POPPR
Ours does it without the emergency brake applied. We will try using the brake in our garage. Might have the opposite effect on ours.
Posted: Tue Feb 08, 2005 11:25 am
by Lecanard
It’s a worn shock mount. I have Chevy cavalier and they go all the time you could almost change them with the air filter.
Re: Anyone have rear suspension squeaks? (Lecanard)
Posted: Tue Feb 08, 2005 8:07 pm
by P POPPR
I think they suspected the shock mount the first time we took it to them. They "lubricated" the area and it didn't change the sound.
Posted: Thu May 17, 2012 8:01 am
by MaxxVibe
I have had this same squeak for some time now on my rear passengers side, it now is on my rear drivers side as of a couple days ago. I dont know what its coming from either. It certainly acts and sounds as suspension related, as i can hear it when im driving the car at low mph and notice it also when im entering/exiting the car and the suspension is under load. I have new shocks on the rear and am suspect to the pivot point of the rear axle assembly. Anybody ever had that checked out? Anybody as of the last time this subject was covered, find out what the culprit is? Its a very annoying noise and drives me crazy because i dont like my cars making noises that shouldnt be there.
Posted: Tue Sep 11, 2018 3:17 pm
by g0ldrush1958
Rear Sway bar is common problem, unbolt and remove It. then clean (bolts an sway bar orifice with brass wire brush) apply lithium white grease on both parts, reassemble, torque to 80ft/lbs. You also can check your rear shock eye bushing!!!
sway bar bolts are hard to remove, make sure to use a two good 1/2 inch socket bar with a 19mm socket and an a tube pipe,
Good Luck!
