Sirius Satellite Radio
Posted: Sun Nov 28, 2004 5:51 am
by PhillyVibeGT
hey everyone, my girlfriend got me sirius radio for Christmas, does anyone have it yet, and where did they install the reciever? I know it comes with the car attachment, but where can we put it? Any help would be great!
Re: Serious Satellite Radio (PhillyVibeGT)
Posted: Sun Nov 28, 2004 6:10 am
by steves76
Yeah I have it here
Re: Serious Satellite Radio (steves76)
Posted: Sun Nov 28, 2004 6:14 am
by steves76
I put the antenna on the side of the roof almost by the rack. Then ran the wire down the weather srip of the hatch. then under the seats to the unit. Was very easy.
Posted: Sun Nov 28, 2004 12:01 pm
by PhillyVibeGT
thanks for the info!
Posted: Sun Nov 28, 2004 12:06 pm
I went with XM, but here's my setup:Receiver:Antenna:
Re: (ragingfish)
Posted: Mon Nov 29, 2004 1:00 am
by PhillyVibeGT
Mike, did you just run the antenna into the other (oem) antenna? And how did you do it?
Posted: Mon Nov 29, 2004 7:43 am
by Jahntassa
Since he's not around, i'll try to answer! He took the headliner down, unscrewed the base of the factory antenna, and using a dremel, cut a little notch at the base of the factory antenna. He then ran the XM antenna through said notch, sealed it all up with silicone sealant on the inside of the roof, and put the headliner back up.
Re: (Jahntassa)
Posted: Mon Nov 29, 2004 8:11 am
Quote, originally posted by Jahntassa »Since he's not around, i'll try to answer! He took the headliner down, unscrewed the base of the factory antenna, and using a dremel, cut a little notch at the base of the factory antenna. He then ran the XM antenna through said notch, sealed it all up with silicone sealant on the inside of the roof, and put the headliner back up.Damn close, but not quite! I actually put the sealeant on the exterior...gooed some on the base of the stock antenna base, and let it pus out when I pushed the base back into place...Just wipe up the excess, and a perfect seal!
