Touch Up Paint
Posted: Thu Jun 06, 2002 7:42 pm
by dlmetzger
Has anyone found a supplier for touch-up paint for the Vibe?
Re: Touch Up Paint (dlmetzger)
Posted: Fri Jun 07, 2002 12:49 am
by d_m_kolb
Your dealership will have this. I have used it and it never looks very good. It's very noticeable after you cover up a chip or what ever it is your trying to cover. If someone has a good way of doing this it would help. I thought about maybe sanding it lightly but I figured this would totally strip the clear coat off so I didn't do that.Turtle wax makes a Color Cure colored wax and it comes with a Chipstik the same color as your car. You use th chipstik on the big cratches and then wax the car with the Color Cure which is th same color as your car. It works great. Covers up the scratcges, chips and swirl marks pretty well. You can buy it at Walmart in the automotive section for around $7.00
