Bugatti Veyron 16.4: What a million dollars can buy...
Posted: Sun Nov 21, 2004 5:37 am
by ragingfish
Technical specs:Curb weight: 4300 lbsSeven gear transmission with dual clutch system, sequential shifting, and a paddle-driven, computer-controlled shifting system that shifts within 0.2 secondsEngine Dimensions (l x w x h): 710 mm x 889 mm x 730 mmEngine: W engine, two V8 banks, arranged at 90°Array: center-mounted, lengthwise in front of rear axleCylinders: 16Piston capacity: 7.993 cmBore x stroke: 86 x 86mmValves: 64, 4 per cylinder, controlled by 4 overhead crankshaftsPower: 736 kw, 1001 hp at 6000 rpmTorque: 1250 Nm (922 ft-lb) at 2200 rpm - 5500 rpmCompression ratio: 9.0Average piston speed: 17.2 m/secSuperchargers: 4 exhaust gas turbo chargersA top speed of 250+ mph (400+ kph)A zero-to-60 time of 3 secondsA zero-to-180 time of 14 secondsA price tag somewhere in the $1 million range.Videos showing the technology and engineering behind the W-16 engine can be found here: * Go to
http://www.bugatti-cars.de * Choose "English". * Along the top, click on "Models" * Choose "Veyron 16.4" * Choose "Engineering" * Choose "Engine" * Along the bottom, choose "Legends from 1001 HP" * Click on video segments 1 through 7 in sequence. You may have to click the play button (small arrow) to get them to play initially.
Re: Bugatti Veyron 16.4: What a million dollars can buy... (ragingfish)
Posted: Sun Nov 21, 2004 7:06 am
by nismo
That thing weighs a lot! But the power makes up for it. That's nice. But I prolly won't have that kind of money anytime soon.Inder
Posted: Sun Nov 21, 2004 7:19 pm
by ColonelPanic
I wonder how many gallons per mile that thing gets?
Posted: Mon Nov 22, 2004 12:11 pm
by soldierguy
Being an engine geek, I'm fascinated with that engine. The fact that I'm an engine geek is also why I ordered the Vibe GT...the more I read about the 2zz engine the more I knew I wanted one.Anyway, that engine has as its root the VW VR6 engine, the one that was in my 96 Jetta GLX. VW wanted a 6-cylinder that would fit in a space designed for 4 cylinders. A conventional 60 or 90 degree V was too wide, and an inline 6 would have been too long. So they made a 15 degree V between the cylinder banks and capped it with a single head casting. Because it has one head covering 2 banks of cylinders, the tops of the pistons are angled to keep them square with the head and keep compression consistent at 10:1 all around. Like an inline engine, the air comes in on one side of the engine, and the exhaust exits on the other side, making for an incredibly complex head casting. And due to space limitations, the exhaust ports are different shapes...they alternate between roughly square and kinda oblong. Looks odd, but it works. The end result was 172-177 hp (depending on if it was installed in a Corrado, Passat, or Jetta), and 173-177 lb-ft of torque. And the sound is amazing on those...little bit of a lope at idle, turning into a brassy moan in the midrange, and a beautiful deep throaty scream at the high end. I bought the Jetta simply because of the engine. Later versions fattened the torque curve, and the latest models are either 2.8L and 200 hp with the new 4-valve head, or 3.2L and 240hp in the Golf R32 or Audi TT 3.2. And for non-north America use, there were also 4 and 5 cylinder variations.The great thing about that engine is its flexibility...the W8 in the Passat W8 is just 2 VR4 engines joined at the crank, and the 16 cylinder model is 4 VR4 engines. I know VW messed with a W12 version (2 VR6 engines) but don't know if it is in production anywhere...might be the engine that's in the VW Paheton 12 cylinder, but I'm not positive.The Bugatti W16 is a great engine...has its roots in a mass produced sedan engine, but it obviously delivers the goods with 1001 hp.
Posted: Mon Nov 22, 2004 1:23 pm
by wicked1981
This car is AWESOME!!!!
Bugatti Veyron 16·4(56k warning)
Posted: Thu Jul 07, 2005 9:57 am
by POLO
(Introducing the impressive new Bugatti Veyron 1001 hpGeneral Info Price: $800,000 Miles Per Gallon: --- mpg Curb Weight: --- lbs Layout: Mid-Engine/AWD Transmission: 7-Speed Sequential Engine Type: Quad-Turbo W16 Displacement: 7993 cc Horsepower: 1001 bhp @ 6000 rpm Torque: 922 lb-ft @ 3500 rpm Redline: --- rpm Performance 0-60 mph: 3 sec 0-100 mph: --- sec Quarter Mile: --- sec @ 112 mph Skidpad: --- Top Speed: 252 mph Braking, 60-0 mph: --- ft Slalom Speed: --- mph
Re: Bugatti Veyron 16·4(56k warning) (POLO)
Posted: Thu Jul 07, 2005 10:18 am
by POLO
Sorry i can't resist to put other picture. The past and the present.And more.
Posted: Thu Jul 07, 2005 10:48 am
by BlueCrush
Holy Crap! I need to go buy a lottery ticket.
Posted: Thu Jul 07, 2005 11:24 pm
by bud_one
One gorgeous automobile....
Posted: Fri Jul 08, 2005 12:45 am
by ScottS
That is the coolest car ever built. What's even cooler is how you get it to hit its top speed.
http://www.autoexpress.co.uk/n....html
Posted: Fri Jul 08, 2005 1:05 am
by Mr. Poopypants
I notice the MPG is blank. Is that because it's actually rated in gallons per mile?
Re: Bugatti Veyron 16·4(56k warning) (Mr. Poopypants)
Posted: Fri Jul 08, 2005 1:55 am
by russ257
that is a hot car. i think the top speed key is a lil stupid since since it only gets you 15.5 mph more then without.while looking around i discoverd this
http://www.koenigsegg.com
Re: Bugatti Veyron 16·4(56k warning) (russ257)
Posted: Fri Jul 08, 2005 4:33 am
by Mavrik
Forget the STI... I know what I want now!
Re: Bugatti Veyron 16·4(56k warning) (Mavrik)
Posted: Fri Jul 08, 2005 5:06 am
by ZubenElGenubi
That is one fine piece of artwork...and yet, somehow that front grill looks familiar:
Re: Bugatti Veyron 16·4(56k warning) (ScottS)
Posted: Fri Jul 08, 2005 7:16 am
by bud_one
the article says "tyre pressure" - is that right?tyre.....?
Re: Bugatti Veyron 16·4(56k warning) (bud_one)
Posted: Fri Jul 08, 2005 11:32 am
by russ257
if you are from england
Fastest (and most expensive) car on the planet!
Posted: Tue Jun 26, 2007 9:28 pm
by ~MRVIBE2006~
If anyone hasn't heard of the Bugatti Veyron, then they are missing out. A car that produces just over 1,000 HP, has 10 radiators, and can go from 0-60 in 2.5 seconds with a top speed of 253 MPH. Yes, I said 253 MPH! The list price, according to the man in the video, is approximately 850.000 pounds or $1,697,624.31 at current exchange rates. This car is AMAZING! Also, when you go to their website http://www.bugatti-configurato....html , the only options that you have when building are the colors of the interion/exterior, stone chip guards and 3 different types of seats.I call this, my LOTTERY CAR. As that I would only beable to afford it AFTER I won the lottery!Enjoy!Heres the link to the video.
http://www.metacafe.com/watch/...yron/
Posted: Tue Jun 26, 2007 9:33 pm
by Sublimewind
Yeah, that's about the sickest thing on the roads anymore... I saw the Youtube spot on it where a guy drove it up past 210mph... It's just crazy... at over 200 the tires will last like 500mi and it'll gulp a tank of gas in 30min or something like that... It has 2 keys, one gives you ~500hp the other gives the 1000hp to you... Crazy
Posted: Tue Jun 26, 2007 9:34 pm
by Sublimewind
Re: (Sublimewind)
Posted: Tue Jun 26, 2007 10:15 pm
by Whelan
This car has been out for a little while now. A lot of people critique it for being ugly. But it's not designed to look like an S500, it's built for speed. When you put in the second key for speed mode, the huge spoiler pops up in back and the car actually lowers itself and has a vacuum system that basically sucks it to the road for traction. Complete with a W16 Quad-turbo setup. They took two W8 engines and basically put them together. P.S. - the W is a volkswagen design.
Re: (Whelan)
Posted: Tue Jun 26, 2007 10:27 pm
by ~MRVIBE2006~
I know it's been out for a little while. But it's nice to stir up interest about such a UBER car. This car is THE speed freaks fantasy car. And just imagine, the wing on this car actually serves a purpose! Unlike all those posers that drill a few holes in their trunk lid and the bolt on some god-awful ugly wing-like thing in there that there is no way that it could help them! Oh well, it is their money to waste! And about wings,I do like the top spoiler on the Vibe. It actually fits it well and looks pretty good. I hope to get one here soon, if possible.
Re: (~MRVIBE2006~)
Posted: Tue Jun 26, 2007 10:34 pm
by Vibr8tr
I think this car looks awsome. I have always liked it from the moment I first read about it. And even though that is the list price, they are usually ALOt more expensive. Just like the Ford GT, it lists on the site at only like $150,000... but if you go to a dealer to buy it you end up paying like $300K.
Re: (Vibr8tr)
Posted: Tue Jun 26, 2007 10:50 pm
by ~MRVIBE2006~
I agree. Even with the list price at $1.7 million, you probably cant touch one for under $2 million.
Re: (~MRVIBE2006~)
Posted: Tue Jun 26, 2007 11:05 pm
by Whelan
That spoiler creates 770lbs of downforce. Imagine that on the back of your hatch, ouch. Not to mention when braking from 250-0 it takes only 10 seconds! The spoiler tilts and creates .5g of deceleration. The driver can let go of the wheel and the car will still brake in a straight line!Oh and in order to go to Top Speed Mode, the car needs to be stopped, the key inserted, and the car does a check on itself and the driver apparently to make sure all is good to go fast!go to wikipedia, it's a sick article!
Re: (Whelan)
Posted: Tue Jun 26, 2007 11:29 pm
by ajflan
Actually, in order to reach its top speed, the spoiler is lowered, to become more streamlined.
Re: (ajflan)
Posted: Wed Jun 27, 2007 1:29 am
by redlava
A million dollars will also buy you about 4,000 of these.
Posted: Wed Jun 27, 2007 1:34 am
by tangerine
Car is Fugly.
Re: (tangerine)
Posted: Wed Jun 27, 2007 1:54 pm
by ~MRVIBE2006~
How did MY topic get hi-jacked and moved? I thought it was in the right place to be posted. I just don't understand and don't like it.
Re: (~MRVIBE2006~)
Posted: Wed Jun 27, 2007 10:32 pm
by millster
Because there were already TWO topics on the same thing that had been posted about a year prior to yours.It wasn't "hi-jacked" I just merged the three together. You received an IM stating that as well.
Posted: Thu Jun 28, 2007 1:47 am
by kostby
My favorite article about the Veyron was in Automobile Magazine -->
http://www.automobilemag.com/r...gatti_ ... orida.html
Posted: Thu Jun 28, 2007 10:09 am
by Pyro-Andrew
Definetly worth it! that car is a thing of beauty!!!
