fender
Posted: Thu Nov 18, 2004 10:33 am
by russ257
I hit a cat the other day and it messed up my front left inner wheel well and then i drove some more and it melted the plastic a bit. I wired it back today. anyone know the part number and an approximate price.
Re: fender (silverawd26)
Posted: Thu Nov 18, 2004 12:11 pm
by AKLGT
yep, i need to replace both of my inner wheel liners too.
Posted: Thu Nov 18, 2004 12:39 pm
by russ257
its the inner wheel lining. i was just gonna remove it and then i realized it is one big plastic piece. oh well 50 bucks isnt too badprolly wait till spring though
Posted: Thu Nov 18, 2004 4:27 pm
by AKLGT
i have about a 1-2" gap between the fenders and the inner linings. so far, no probs and it's been like that since March. plus i have a CAI. speaking of which, i should probably look at cleaning that filter.
Re: fender (trdvibe)
Posted: Thu Nov 18, 2004 9:42 pm
by russ257
i was thinking about it and prolly should replace it before winter so i dont get salt up inside the body any more then nessicary. or i could use duct tape
Re: fender (russ257)
Posted: Fri Nov 19, 2004 6:09 am
by AKLGT
Quote, originally posted by russ257 »i was thinking about it and prolly should replace it before winter so i dont get salt up inside the body any more then nessicary. or i could use duct tapeha ha! duct tape is a STAPLE of life here in alaska!
Posted: Sat Nov 20, 2004 10:35 am
by zionzr2
you only need 2 tools..WD40 and Duct TapeIf it moves and shouldnt use the duct tapeIf it dont move and should use WD40
Re: (zionzr2)
Posted: Mon Nov 22, 2004 4:09 pm
by AKLGT
i'll try and take some pics of my fender lining and what i did. one side all done and will finish off the other side tomorrow... new fogs, re-oiled the TRD filter, fixed (sorta) the inner fender lining, hacked up the lower grill.... and will try and finish up tomorrow night! will post pics later.
Re: (trdvibe)
Posted: Mon Nov 22, 2004 10:55 pm
by AKLGT
ok, here are some of the pics of the damaged fender lining on the passenger side of the car. you can see the big gap there that would allow a lot of moisture inside the wheel well. the broken piece of the liner. the screw hole ripped and now doesn't stay in place.now the fixed liner on the driver's side, your vibe should already look like this. i used flashing for roofing and made a patch. i'll get some pics of it so you can see what exactly i did. but i folded it in half and drilled a hole to reinforce the screw. this is looking at it from the floor.
