Exhaust
Posted: Mon Nov 15, 2004 9:05 am
by SuPeRioN81
I just put in a Magnaflow exhaust on my Vibe GT. I love the sound. Just thought I'd post that. Have a nice day.
Re: Exhaust (SuPeRioN81)
Posted: Mon Nov 15, 2004 10:17 am
by Raven
Well done! I just put a Flowmaster on my truck. It sounds wickedly mean. The Vibe is next.
Posted: Mon Nov 15, 2004 10:56 am
by nismo
Did you put it on yourself or did you get someone else to do it for you? If you did yourself, how did you cut the exhaust pipe?Inder
Re: Exhaust (TRD4reel)
Posted: Mon Nov 15, 2004 11:38 pm
by ToolGuy
I have used a hand cutter for exhaust pipes. It has four round cutting wheels and works like a pipe cutter. As you turn, you also tighten and the cutters cut the pipe. Makes a nice cut and works, bought it at Murrays and cut the cat off my wifes old car to put a straight pipe on it.
Re: Exhaust (MiVibe-ToolGuy)
Posted: Mon Nov 15, 2004 11:41 pm
by nismo
how much do they run?
Posted: Mon Nov 15, 2004 11:47 pm
by ToolGuy
Sorry I do not remember it was 3 years ago. It is a hand tool and I know did not cost much. If you have room a SawsAll (reciprocating saw) and a metal cutting blade would work too.
Re: Exhaust (silverawd26)
Posted: Mon Nov 15, 2004 11:51 pm
by nismo
I'm gettin an exhaust for my car soon. Im getting the Magnaflow. I was just wondering what kind of tools people use to cut the pipe. Could a jigsaw work also, with a metal cutting blade?Inder
Posted: Tue Nov 16, 2004 12:27 am
by ToolGuy
With a radius on the pipe and its outer diameter, that type of saw might have a hard time starting the cut. Plus the blade may not be long enough, at least on my jig saw they seem too small. JMO though...
Posted: Tue Nov 16, 2004 12:34 am
by ToolGuy
Just look for a good place to have it done Inder if you cannot do it. I took my Vette to Midas to align one of my Vettes exhaust tips and the guy says something like $50, one hours labor. I said no way put the car on the ground. I said I would think just to heat the pipe and bend it maybe $10, the kid says OK wait here and after I finish up this car I will do it. Of course he pocketed the money and then when he took my car off the lift he drove it down to the end for that parking lot and back to me. He not do anything bad with it and I would have his (removed) if he did but he wanted to drive it! What an (removed)! Did not know where else to take it, I had my exhaust tips to install at the time and I did not want to leave it unattended.
Posted: Tue Nov 16, 2004 5:17 am
by nismo
I would rather do it myself, because, if it does mess up, I know how to fix it. If I have the shop do it, then if something goes wrong, I won't know what to do. That is why, almost any mod that I do, I would like to do it myself, unless it's like, getting internal motor work done to it.Inder
Re:
Posted: Tue Nov 16, 2004 5:24 am
by Mase
Make sure to check for leaks (indicated by soot) in a week or two. My clamped joint had a little leak so I added a second clamp. It seems to have sealed it up. Also, did you reset your ECU?
Re: Re: (Mase)
Posted: Tue Nov 16, 2004 5:27 am
by nismo
If you're talking about me, then no because I have not purchased it yet. But, other than that, I will keep an eye on that when I do install it Inder
Re: Re: (TRD4reel)
Posted: Wed Nov 17, 2004 6:50 am
by dante
I put a Borla exhaust on my 2003 Base model and it took me only about 15 minutes.it is a easy bolt on. the only thing is its a little expensive about $400 but it is a life time warranty so if you plan on keeping your vibe like me it will pay for itself in no time and it sounds great and runs better.
Re: Re: (TRD4reel)
Posted: Wed Nov 17, 2004 9:55 am
by Raven
You can rent a pipe cutter or use a grinder with a cut-off blade as I did on my truck. A saws-all will work but it will shake the crap out of you and make a really rough cut.
Re: Re: (dante)
Posted: Wed Nov 17, 2004 10:46 am
by nismo
hey dante, thanks for the info for the Borla, but I want to go with a true cat-back exhaust system. And Sunny, that's for the info. I will contact a home depot or any hardware shops next to my house.Inder
Re: Re: (TRD4reel)
Posted: Thu Nov 18, 2004 7:35 am
by dante
the Borla is a true cat back exhaust system
Re: Re: (dante)
Posted: Thu Nov 18, 2004 10:18 am
by nismo
Really? I was under the impression that the Borla was not a true cat-back exhaust because I know for a fact that the Magnaflow comes with a mid-pipe and I was told that the Borla did not come with the midpipe.Inder
Re: Re: (silverawd26)
Posted: Thu Nov 18, 2004 10:39 am
by nismo
I heard Redlava's setup. He's got everything I do, but he's got the Magnaflow. I liked the way it sounded. He had a slight rattle in it, but other than that, it was fine.Inder
Re: Re: (TRD4reel)
Posted: Sat Nov 20, 2004 9:29 am
by dante
The borla hooks up at the flange behind the cat two bolts and it is in they call it a cat back system unless you want to cut the pipe behind the cat but why would you want to do that and I think it sound real good.
Re: Re: (dante)
Posted: Mon Nov 22, 2004 7:45 am
by Psychobroker
Quote, originally posted by dante »the Borla is a true cat back exhaust systemNo it isn't. They LABEL it as a "cat-back" for sales purposed, but ask any dealer if it comes with a resonator, and they'll say it doesn't.
Re: Re: (Psychobroker)
Posted: Mon Nov 22, 2004 9:48 am
by nismo
Yeah. thanks for verifing that for me Psychobroker. This is the reason I am going with the Magnaflow. Inder
Posted: Mon Nov 22, 2004 12:26 pm
by damronjr
Flowmaster cat-back here on the Vibe. I love the sound. Wanted to hear the magnaflow, but the place I was out was out of the one's for the Vibe at the time.
Re: Exhaust (damronjr)
Posted: Mon Nov 22, 2004 8:54 pm
by dante
well all of this is nice to know I thought that the borla was a cat back system I still love it but I am going to get a AWD in Dec so maybe I will put a magnaflow on this one. My wife wants my 03 Vibe she loves it. I found that the best price so far was $395 for it on line is that a good price?
Re: Exhaust (dante)
Posted: Mon Nov 22, 2004 10:15 pm
by drunkenmaxx
Quote, originally posted by dante » I am going to get a AWD in Dec so maybe I will put a magnaflow on this one. youll have to go custom, there is now catback for the AWD.
Posted: Tue Nov 23, 2004 3:01 am
by Merzbow
Yeah Rob, after hearing mine and Rasermon's Borla GT exhausts, I'm glad I bought Borla instead of Magnaflow like I was going to.It would make sense the Borla is cat-back since it start's after, or "in back of" the catylic converter...I dunno just how I interpret the word cat-back.
Posted: Wed Nov 24, 2004 8:06 pm
by dante
I love the sound of my Borla
