17" Wheel and Tire Size
Posted: Sat Nov 13, 2004 2:30 am
by platinum_
hey guys, i have a 2003 GT , with the 17" Rims, what is the size of the tire? and the width ? i have looked around and cant find exactly which winter tires to get, i found a calculator so i just need the original size thanks.
Re: 17" Wheel and Tire Size (platinum_)
Posted: Sat Nov 13, 2004 3:20 am
by AKLGT
hey, platinum. if you do a search, you'll find a LOT of threads on this. in fact i just posted in one last night on the same exact question on which winter tires to get for the 17" wheels. are you keeping them on the 17's or you going with 15's or 16's like most of us have?
Re: 17" Wheel and Tire Size (trdvibe)
Posted: Sat Nov 13, 2004 3:21 am
by AKLGT
try this thread, also links to a few others. http://forums.genvibe.com/zero...65383
Posted: Sat Nov 13, 2004 3:26 am
by platinum_
thats for the reply, but it doesnt say the actual size anywhere for the GT 17" option, i only foujd this : "I currently have factory 215/50-17's" , but am not sure if it is the same size as the GT, i am looking to put on some steel 16" , and will find the appropriate size if i can figure out the size of the ones i have now, thanks.
Re: (platinum_)
Posted: Sat Nov 13, 2004 3:28 am
by AKLGT
well, i'll have to look at that and see.... just a sec.
Re: (platinum_)
Posted: Sat Nov 13, 2004 3:34 am
by AKLGT
yes, that should be it. there are no difference on the 17's between GT or base models, just whether or not the tires were the factory 17's.
Posted: Sat Nov 13, 2004 3:50 am
by platinum_
mine are the Dunlop summer tires on the 17" upgrade, with the low profiles, i hope its the same thanks your help.
Re: (platinum_)
Posted: Sat Nov 13, 2004 3:54 am
by AKLGT
later today, i'll go check mine out. i have the same, and changed them over a few wks ago. then will confirm that's the correct size.
Re: (trdvibe)
by MadBill
215/50 -17 is the one and only 17" stock Vibe tire
Re: (MadBill)
Posted: Sat Nov 13, 2004 6:25 am
by AKLGT
yep. 215/50/17 are it! just verified my tire size too.
Posted: Sat Nov 13, 2004 6:50 am
by platinum_
thanks alot guys :D
Posted: Sat Nov 13, 2004 7:00 am
by platinum_
i used the calculator and i think i've found the perfect size for my vibe. P205/65R/15 , the calculator shows a 0.1% difference from the P215/50R/17 :D
Re: (platinum_)
Posted: Sat Nov 13, 2004 10:16 am
by AKLGT
Quote, originally posted by platinum_ »i used the calculator and i think i've found the perfect size for my vibe. P205/65R/15 , the calculator shows a 0.1% difference from the P215/50R/17 :Di believe those are the same size wheels i have. i posted it up above if i remember correctly.
Re: (trdvibe)
Posted: Sat Nov 13, 2004 10:19 am
by AKLGT
Quote, originally posted by trdvibe »i believe those are the same size wheels i have. i posted it up above if i remember correctly.oops, sorry, i posted it in another thread:Quote, originally posted by trdvibe » depends on what rims you are going from... 16" or 17"?i have 17" OEM rims and tires and went with 15" steelies and 205/65/15 studded Hancook snow tires. the 60 was not close enough in diameter.also see this similar thread: http://forums.genvibe.com/zerothread?id=6398
