Satellite radio placement
Posted: Sat Nov 06, 2004 9:43 pm
by thermometer
I just bought a Roady 2 because it has wireless FM transmission and I do not have to hard wire it into my Vibe. I travel with other cars sometimes and I want to take the Roady with me. It actually sounds pretty good. But, I'm having trouble figuring out where to mount it in the Vibe. There's not much room on the Vibe dash. Any ideas? Ralph
Re: Satellite radio placement (thermometer)
Posted: Sat Nov 06, 2004 10:49 pm
by tboynes
I used the vehicle specific mount sold at
http://www.myradiostore.us/ also used the Bracketron PH-Mini 4also sold at the store to make the Roady removable from the car when parked. I installed a pig tail lighter adapter behind the dash to supply the power in a more discreet way. The 3 wires from the Roady slip under the radio trim (after removing just a little bit of plastic from the non visible side of trim). Tom
Posted: Sat Nov 06, 2004 10:54 pm
by Jahntassa
I used the same method. However, if you want a device to move from vehicle to vehicle, you probably should've gone with the SkiFi2, which also has an FM Modulator. The Roady's have been known to have their connectors deteriorate over time if moved a lot, as they're not really designed to be constantly disconnected.
Posted: Sat Nov 06, 2004 10:56 pm
by tboynes
Sorry about the size of previous attachment here is picture that will fit in the screen.Tom
Posted: Fri Nov 12, 2004 8:24 am
by thermometer
Thanks everyone for the advice. Very interesting. This information helped me find a good web site with various mounts.
http://www.myradiostore.us/mounts-brackets-tools/
Posted: Fri Nov 12, 2004 1:52 pm
Also check out
http://www.pro-fit-intl.comThey make a bunch of stellar mounting devices!
Posted: Mon Dec 05, 2005 8:21 am
by thermometer
I removed the button on the panel that does nothing and it left me with a flat surface. I mounted the Roady there with velcro. Here is a photo. Works nicely.
Posted: Mon Dec 05, 2005 9:23 am
by Jahntassa
Doesn't interfere with the wipers at all?It does look really clean..that's for sure.
Re: (Jahntassa)
Posted: Mon Dec 05, 2005 10:03 am
by thermometer
Doesn't interfere at all. It's the best place I could think of to mount the Roady. Please not that when sitting in the driver's seat, since you would be looking at the Roady from a slightly different angle than the straight shot photo, you would not see the extreme left side of the unit, but that has never interfered with changing stations or general use of the unit.
