car spkr install fron doors
Posted: Thu Nov 04, 2004 1:13 am
by 79 beast
how do you take interior door insert off to put in new car spkrs
Re: car spkr install fron doors (79 beast)
Posted: Thu Nov 04, 2004 3:44 am
Pop the little cover behind the door handle, remove that screw.Remove the screw from the door bin.Pull it off to disengage the retaining clips.Be sure to unplug the window and door lock controls!
Re: car spkr install fron doors (ragingfish)
Posted: Thu Nov 04, 2004 6:36 am
by 79 beast
the inst cohocarl were great made it soo easy.thank you.now i have to figure out how to hook up my 400 watt amp to the rear spekers and sub on the wiring harness.amp takes high and low inputs.guess the amp has to go in the back because it wont go under the seats
Posted: Thu Nov 04, 2004 8:16 am
by cohocarl
Quote, originally posted by 79 beast »the inst cohocarl were great made it soo easy.thank you.Glad it helped. I can't find it off hand, but somewhere here on the forum is a schematic of the wiring harness that shows which wire is what.
Re: car spkr install fron doors (cohocarl)
Posted: Thu Nov 04, 2004 10:59 pm
by 79 beast
under the passenger seat there is a hollow bar with a grey and white wire.is that a right rear speaker .i know the stock subwoofer amp mounts there so i was wondering if there is power that was preinstalled for the sub.since i bought the basic sound system,and i have nothing.also does the amp mounts on brackets like the power converter or can i velcro it to the rug
Posted: Fri Nov 05, 2004 1:51 am
The passenger seat wire harness you see would likely be for the M&T amp.The factory subwoofer, when ordered, is in the rear cargo area in the passenger-side sidewall.The amp, when coming from the factory, is also raised off the carpet like the power inverter. However, many people just leave their aftermarket amps on the ground...
Posted: Fri Nov 05, 2004 4:43 am
by 79 beast
thanks .what is the 11 pin connector under the passenger sill .is it the amp wiring.ift it is can i use it for the aftermarket amp and what colors are for what speakers.just want to amplfied the 2 rear speakers and a sub woof
