DRL - High or low
GoLowDrew
DRL - High or low
Post by GoLowDrew »
Is the DRL high or low beam.
2004 Vibe, Auto Trans. Built Sept 2003. Date in service May 2004. Sold May 2006.
Jahntassa
Post by Jahntassa »
It's the low beam at 80% power.
nismo
Re: (Jahntassa)
Post by nismo »
I disabled mine so, I don't even have to worry bout that anymore.Inder
Re: DRL - High or low (GoLowDrew)
Definitely low beam... When my $ilver 's died, I still had high beams but no lows, and no DRL's.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
GoLowDrew
Post by GoLowDrew »
Shouldn't the DRL be high beam at 30%?
Mase
Post by Mase »
I'd prefer that my hi-beams be the drl's too because they're more visible during the daytime than the lo-beams due to their higher projection.I've been studying wiring schematics of the lighting system, but haven't yet been able to figure out if switching drl's to the hi's is possible.
Jahntassa
Post by Jahntassa »
Not without modifying the DRL control box, probably. And DRLs should never be high-beams, due to the projection. Even at 30%, it stands to shine in the eyes of other drivers, which would never fly with the D.O.T.
GoLowDrew
Re: (Jahntassa)
Post by GoLowDrew »
I recall when DRL first came out (late 90s) it was the high beam @ 30%. Even today, other Toyota products such as Camry is at high beam @ (about) 30% DRL.
zionzr2
Post by zionzr2 »
The 98-99 S-10 used the highbeam for DRLS at redused power the recalled them to switch it to the Low Beam due to blinding others was the complaint.
A lot of cars, lately, are implementing a 3rd bulb that is solely a DRL bulb...Smart move IMHO!
Re: (ragingfish)
The third bulb is a good idea... Now, when the implement DRL's into the turn signals up front, then we have a problem... They burn out pretty quick, so you'll lose your turn signal.
Neptune/primer/rust
esjones
Re: (ragingfish)
Post by esjones »
Quote, originally posted by ragingfish »A lot of cars, lately, are implementing a 3rd bulb that is solely a DRL bulb...My 98 Intrigue uses the amber parking lamps as the DRL. It's not a new thing..
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
Re: (esjones)
Quote, originally posted by esjones »My 98 Intrigue uses the amber parking lamps as the DRL. It's not a new thing..I meant a third bulb completely independent of anything else, which serves no purpose other than DRL. Was not referencing the ambers.You see it on trucks a lot, but now I'm seeing Camrys with it too...Note here: 4 bulbsAmberLowHighDRL
