Dash Rattle: left of steering wheel
Posted: Fri Nov 01, 2002 12:09 am
by mkl116
Has anyone experienced dash rattle to left of steering wheel. It comes and goes depending on engine speed and road conditions. Just applying pressure to points while I drive has no impact so I suspect it is up inside. Any insight would be appreciated. Thanks...
Re: Dash Rattle: left of steering wheel (mkl116)
Posted: Fri Nov 01, 2002 12:18 am
by Sub-Vibe-R
Take a look at this post. It could be the answer at your question
Posted: Fri Nov 01, 2002 12:43 am
by NSimkins
Left of steering wheel could be the A-Pillar, which I do currently have something loose inside there. Depending on temperature and road conditions affect if and when I hear the noise. However, I can bang on the pillar and recreate the noise most of the time. Probably some loose wiring. I will be taking it off this weekend to fix.Also, the dash pods (gauge) area could be making a squeaking noise or ticking noise (different sounds depending on temperature). This has been fixed in this thread:
http://forums.genvibe.com/zerothread?id ... 2Somewhere inside the middle of my dash, I get a vibrating plastic noise when accelerating.. but this is also dependent on temperature and rpm's. Still haven't found a way to fix it without dealer intervention, however I don't believe they would find it.
Re: Dash Rattle: left of steering wheel (NSimkins)
Posted: Fri Nov 01, 2002 3:30 am
by Sub-Vibe-R
Sorry, I forgot to copy the post in my last reply.......
Re: Dash Rattle: left of steering wheel (Sub-Vibe-R)
Posted: Fri Nov 01, 2002 8:01 am
by mkl116
Thanks! The instrument cluster sounds like a likely culprit. I'll give it a shot tomorrow.
