Dynomax Super Turbo
Posted: Fri Oct 15, 2004 9:55 am
by bjlarson
Well, I decided to follow drunkenvibe's lead and go with just replacing the stock muffler with a Dynomax Super Turbo Muffler. I got a quote from local shop for $160 installed. I will let you know how much of a difference I feel. I replaced the stock air filter with a K&N Filtercharger ($58+tax)drop-in replacement filter. My next mod is a Unichip. I am leasing my vehicle so I want it to look as stock as possible but also be able to get as much power as I can out of it.
Re: Dynomax Super Turbo (bjlarson)
Posted: Tue Oct 19, 2004 2:59 am
by Merzbow
Sounds good to me Just get removable parts and switch them back when lease is up.
Re: Dynomax Super Turbo (Merzbow)
Posted: Tue Oct 19, 2004 7:37 am
by bjlarson
Well, I had the Dynomax Super Turbo Muffler installed today and I also installed the K&N Filtercharger. After installing I had to take a test drive and I must say there is quite a difference. Before the acceleration was pretty lame and now I can fell the vehicle pulling when it accelerates. Definitely worth the minimal investment. I would recommend it to Vibe owners who want a little extra kick but don't want to spend a lot of money to get it.Later,Brian
Posted: Tue Oct 19, 2004 8:45 am
by shocker sf
Get some Pics B
Re: (shocker sf)
Posted: Tue Oct 19, 2004 8:59 am
by bjlarson
Here is on if the new muffler with the Chrome Exhaust tip. The new muffler has a nice deep mellow sound to it. You can also see the underbody rust protection.
Re: (bjlarson)
Posted: Tue Oct 19, 2004 9:39 am
by Merzbow
that undercaraige looks awsome!
Re: (Merzbow)
Posted: Tue Oct 19, 2004 11:16 am
by bjlarson
Thanks, hopefully it will stay that way for a while!Brian
Re: (bjlarson)
Posted: Thu Dec 09, 2004 6:37 am
by bud_one
What are the specs on the muffler you had installed.I'm intrested in using the same muffler on my car.
Re: (bud_one)
Posted: Thu Dec 09, 2004 7:05 am
by Turbo5Speed
Other good inexspensive mods:Spark plugsGround wiresThermal wrap (On exhaust)
Re: (Turbo5Speed)
Posted: Thu Dec 09, 2004 7:16 am
by nismo
Well, from what I have heard, the factory plugs are quite good.Inder
Re: (TRD4reel)
Posted: Thu Dec 09, 2004 9:40 am
by Turbo5Speed
They're alright, but aftermarket plugs will still improve performance. If you wanted to upgrade the electrical system even further, look at some of the fine products offered by MSD Ignitions.
Re: (bud_one)
Posted: Thu Dec 09, 2004 10:46 am
by BlueCrush
I got the SuperTurbo it sounds awesome. Not too loud, nice and deep at low rpms and pretty quiet when cruising. Here are the specs from the dynomax web site:
http://www.dynomax.com/superturbo.stmAlso here is a sound file for a 2000 Honda Civic 1.6L VTEC with an Ultra Flo Muffler. It sounds very close to mine:
http://www.dynomax.com/audio/track19.wavLater,BrianP.S.- Just found a .pdf file for the SuperTurbo Specs also:
http://www.dynomax.com/documen...s.pdf
Re: (Turbo5Speed)
Posted: Thu Dec 09, 2004 10:52 am
by BlueCrush
The stock plugs are NGK Iridium plugs. There is not much better out there. If there is something better the difference will be so minimal that you will not notice a difference. I should know, I have found better and there is no noticeable difference.Brian
Re: (BlueCrush)
Posted: Thu Dec 09, 2004 11:03 am
by Raven
Quote, originally posted by BlueCrush »The stock plugs are NGK Iridium plugs. There is not much better out there. If there is something better the difference will be so minimal that you will not notice a difference. I should know, I have found better and there is no noticeable difference.Brian They're good for 200,000 Km or 124,000 miles according to the service manual.
Re: (BlueCrush)
Posted: Thu Dec 09, 2004 9:04 pm
by MoonDogg
Correct me if I am wrong, but I was almost sure the owners manuel says stock plugs are Denso Iridium. No a huge difference just about $10 a plug more I know there is a better Iridium's to put in.. but any thing other than that is usless.
Re: (BlueCrush)
Posted: Fri Dec 10, 2004 12:07 am
by dartagnanpluck
Nice to see another AWDr that got some extra juice. Did you jut put the 2004 parts in the 2005, crossing your fingers? I can't find 2005 stuff anywhere yet.
Re: (dartagnanpluck)
Posted: Fri Dec 10, 2004 12:38 am
by BlueCrush
The air filter is the same, the plugs are the same, and the muffler is a universal fit and is quite a bit smaller than stock so the fit was no problem.Brian
Re: (BlueCrush)
Posted: Fri Dec 10, 2004 1:15 am
by ToolGuy
Had two DynoMax mufflers on my fist car 1987 Cavalier RS. I loved the mellow sound they produced, no fart can. Good quality too! Stick with the stock plugs, you will not feel a difference in performance in changing them out.
Re: (MoonDogg)
Posted: Fri Dec 10, 2004 5:32 am
by MadBill
Quote, originally posted by MoonDogg »Correct me if I am wrong, but I was almost sure the owners manuel says stock plugs are Denso Iridium. No a huge difference just about $10 a plug more I know there is a better Iridium's to put in.. but any thing other than that is usless.Denso is the parent company of NGK. AFAIK, apart from the logo they are the same plug. (Which isn't to say they couldn't be priced very differently...)BTW, Denso iridium plugs are now factory installed in many GM products.
