iPod AND factory XM?
Posted: Mon Oct 11, 2004 1:40 pm
by Natron
Is there any aftermarket solution that will enable hooking an iPod up direct to the factory 1 CD w/Moon & Tunes, 6 speaker, with factory XM, and still be able to use the factory XM???I know an FM modulator would work, but would hate to sacrifice sound quality.This would be on a 2005 model.
Posted: Mon Oct 11, 2004 8:23 pm
by Jahntassa
You -might- be able to use the PIE X3 adapter. It works with the 03/04 Nav system because the Nav has the changer. I don't know any specifics about how things are connected in the '05's though..
http://www.xmfanstore.com/showproduct.php?id=piex3I have the X3GM12 with my nav system. Plugs in behind the radio between the radio and the changer cable.
Re: iPod AND factory XM? (Natron)
Posted: Mon Oct 11, 2004 11:32 pm
by GMJAP
Try looking at PAC-Audio's AAI-GM12 adapter. Supposedly, it works with with a slave system (like XM), and has a switch that allows you to select between XM and an AUX input (iPod).
http://www.pac-audio.com/products/aai.htm
Posted: Tue Oct 19, 2004 8:00 am
by quietcoolone
Natron,this may be what you are looking for.. it's the same product i used to add my iPod mini to my 2005 Vibehttp://www.discountcarstereo.c...D=446PIE claims that it works with the factory xm or factory changer installed.Good luck.
Posted: Tue Oct 19, 2004 8:29 am
by Natron
Thanks! I was debating at weather to go Factory XM or External XM, but seeing as how I don't have a Vibe yet, and I want to get XM before then, I've pretty much decided to go with external XM using a SkyFi radio.
