Re: oil running down your arm!!!!!! (glassman)
Posted: Sun Mar 13, 2005 2:45 pm
				Quote, originally posted by glassman »try taking a small center punch or philips screw driver  and punch a hole in the filter before you take it off let it drain while you take the drain plug out then once it is done remove filter no mess to clean easy as 123Damn! That's a good tip there bud! Thanks!
