Page 2 of 2
Re: How-To: Cleaning MAF (Mass Air Flow) Sensor (jkm311)
Posted: Mon Dec 12, 2011 6:50 am
by erch
Great posts. I cleaned the MAF several times - didn't read far enough down to see the post about the wires needing cleaned. Finally got it cleaned up and started the engine - ran great because it was already warm. Went back outside about a half hour later and it started up and with the temperature around 45* it idled rough around 500 rpm. I drove a few miles and it was still tough, but after about 10 miles it ran really well - idle back up to 750 or so when i put it in park. it was idling around 500 in drive just before that. A new MAF or another cleaning? I used electronic cleaner because that is what I had. I wonder if it was not strong enough. I noticed one side of the amber colored temp bulb looked sorta pitted - it had discolored dots on it - even after it was cleaned.Also, I am looking on ebay for a new part - why would the 2005 part not fit a 2006?
Posted: Mon Dec 12, 2011 10:23 pm
by jasonvibe
Yes, You are using the correct cleaner. Because you are JUST cleaning dust dirt and oils off the MAF. Do NOT use carb cleaner or anything that strong. FYI- There are 2 parts to the MAF. Temperature sensing and Air Flow. The bulb is the temp sensor. Pitting-That may be bad in your case. FYI-CLEANING The MAF does NOT fix EVERYTHING. You may have a sticky IDLE air control. 2003-04 FWD and 2003-2006 AWD have this issue sometimes. I did... Also, what part are you looking for?
Posted: Mon Oct 08, 2012 6:44 pm
by ToBScholarly
Hi folks!
Just wanted to say THANK YOU to all those who took the time to post and contribute to this thread many moons ago. I just used it to clean my MAF and it cleared my CEL right up! The directions were super easy to understand and all the comments were very helpful.
I have never done ANYTHING on any car before now but the close up pictures and descriptions empowered me. My 12 year old even helped out.
Thanks again for keeping my Vibe healthy!
Posted: Mon Oct 08, 2012 7:47 pm
by KITT222
Can somebody please clear the air for me regarding carb cleaner, and if I can or can not use it to clean my MAF?
Posted: Tue Oct 09, 2012 9:01 pm
by star_deceiver
KITT222 wrote:Can somebody please clear the air for me regarding carb cleaner, and if I can or can not use it to clean my MAF?
Don't take the chance. The can of proper Mass Air Flow sensor cleaner should only cost around $3/$4.
Posted: Wed Oct 10, 2012 3:01 pm
by ToBScholarly
star_deceiver wrote:KITT222 wrote:Can somebody please clear the air for me regarding carb cleaner, and if I can or can not use it to clean my MAF?
$7.99 at Advanced Auto Parts.
Posted: Wed Oct 10, 2012 4:55 pm
by star_deceiver
ToBScholarly wrote:$7.99 at Advanced Auto Parts.
Just checked... must have grabbed mine while it was on sale. $7.99 at Cambodian tire. Still... one can should last the life of your vehicle!
Posted: Wed Oct 10, 2012 7:12 pm
by KITT222
Asked question, then realized I had a can of MAF cleaner. Cleaner MAFs for the whole family! This weekend only!
Posted: Sat Oct 13, 2012 11:09 am
by vibenvy
vibenvy wrote:I cleaned our MAF/IAT sensors today. I picked up a can of CRC QD Electronic Cleaner at Walmart for less then $5.00.
After doing a little more research online about cleaning the MAF sensor, I discovered the two most important things to look for in a cleaner are "quick drying" and "leaves no residue", both of which are stated right on the can of the CRC QD Electronic Cleaner.
Just a reminder that it doesn't
have to be MAF cleaner. I have used the above electronics cleaner a couple times now without issue.
Posted: Mon Oct 15, 2012 6:39 pm
by Mark
I clean mine twice a year when I replace the air filter element, it only takes a minute to pull it out and spray it off. I don't disconnect the battery when I do mine, but I did the first time I cleaned it when it was really dirty and I was having performance issues. If it's not that dirty I don't think there's any real benefit to resetting the ecm every time.
One can of CRC MAF cleaner lasted me several years, and I spray the crap out of it. Also use it on the MAP sensor in my truck, but I have to soak that in brake cleaner first, and then I use the MAF cleaner to spray off any residue.
Posted: Fri Jun 14, 2013 5:10 pm
by stinkypete
I have a 2004 GT and was getting a stumble off the line, saw this and cleaned my MAF w/ CRC brake cleaner and stumble is gone. Thx
Posted: Mon Jul 01, 2013 8:13 pm
by triz
Cleaning the MAF does wonders. I like to clean the MAF, throttle body, and run some Amsoil PI Performance Improver through the fuel system when I do it.
Posted: Wed Jul 10, 2013 10:13 am
by fpsfreak209
ok so i did this.i allowed about 15 minutes to dry.i started car for 20 secs.it seemed fine.10 minutes later i started again and now car shakes way more.did i mess up the maf sensor? if so should i buy a used one from pick in pull or a new one? it shakes even more when i go in reverse.
Posted: Wed Jul 10, 2013 12:17 pm
by ehoff121
fpsfreak209 wrote:ok so i did this.
Did you disconnect the negative battery cable before doing it?
Posted: Wed Jul 10, 2013 2:09 pm
by fpsfreak209
ok it looks like it got fixed.i guess i needed to let the car run for more minutes.computer needed to relearn all the stuff.i did some research.so far so good.i noticed engine rumbles slighly lower now.so good thing i got it cleaned. car stopped on me before stop sign so i guess beware after u do this.drive safe
Re: (06pvibe)
Posted: Thu Aug 01, 2013 2:16 am
by canadave
jkm311 wrote:Did the procedure again, right before a 780-mile car trip this weekend. And man, am I glad I did. The Vibe wasn't down-shifting on slight inclines with cruise engaged (even with the AC on), and I generally enjoyed better performance at various speeds/conditions.However...I'm wondering if cleaning the MAF really had anything to do with the gains. I say this because when I pulled my MAF out, it looked to be much cleaner than when I wrote this how-to. The amber temp "bulb" was shiny, and the thin wires up into the actual MAF looked shiny as well. Not dull with residue. I think this has a lot to do with me getting better at cleaning and re-oiling my K&N drop-in filter. Could just disconnecting the negative on the battery and re-setting the ECU produce the same results (with a clean MAF)?Hmmm...No matter what, the lower RPMs at all times = smoother ride, and most likely a few less drops of gas used up.
Just stumbling across this thread...did we ever get a satisfactory answer to the question in bold? I'm a complete amateur at cars, but it seems to me that this seems a lot more likely explanation for such immediate dramatically improved performance than a more clean MAF sensor. Thoughts?
Posted: Fri Aug 02, 2013 6:18 am
by Salsa Guy
Unless you have a large chunk of crap in the MAF cleaning it can do more harm than good. If you insist on cleaning it or the TB then pulling the Negative side off the battery BEFORE you work on it does 3 things. Takes the risk out of damaging the MAF, resets the ECU and is a layer of safety.
Posted: Mon Aug 05, 2013 7:55 am
by shaeet
I was having some acceleration problems on my XRS this past week. At lower-midrange RPM's the car felt like it had no balls. I previously cleaned the MAF but after looking at this thread I didn't really clean it, I cleaned the temp sensor only thinkin that was the MAF.
So i removed it again on friday & sprayed the hell out of the wires. They were visibily dirty. Popped it back on & instantly the car drove like before with strong acceleration. I recently sprayed my Injen's K&N cone filter w/oil & cleaner and I suspect some of it might have gunked up the MAF causing the issue. If I run into the same problem later I'll definitely know what to do :thumbup:
