Page 2 of 2
Re: Supercharger installed! (Lancer)
Posted: Sun Oct 02, 2005 3:38 pm
by Faultline
Quote, originally posted by Lancer » I'm sure I'll be in the 14s.(going after Faultlines record on Monkeywrench.com )I forgot that I posted that there!!I always think my time should be better..I was going aroun 97mph my the end, and my 60ft times were at 2.5. Which really is not that good. Damronjr, that is where you need to do better if possible, in your 60ft time. 2.6 is not so good. I have been told that in the 1/4 mile, for every 10th you save in the 60ft , you will save 2 10ths off your time. I know 2 guys with wrx's. They both have gotten 13.7 at 1/4 mile. Their top speed is 96mph, when I race them on a role, I win. Their advantage is AWD, and their 60ft times are 1.9...That is how much launches matter for a good time. Honestly, good launches escape me though!
Re: Supercharger installed! (Faultline)
Posted: Wed Oct 19, 2005 10:42 pm
by damronjr
Well, as promised, here's a lousy short video. I'll try to work on getting a better support for the camera and open the car up more so you can hear it better. I found it is a lot easier to use my digicam than my video cam since the .mov's can be saved directly to my comp whereas I don't know how to do it yet with my video cam.
Attached files sc.wmv (324.4 KB)
Re: Supercharger installed! (damronjr)
Posted: Wed Oct 19, 2005 10:50 pm
by BlueCrush
Sounds good, Jason! Hope to see more in the future.
Re: Supercharger installed! (BlueCrush)
Posted: Wed Oct 19, 2005 10:52 pm
by damronjr
Quote, originally posted by BlueCrush »Sounds good, Jason! Hope to see more in the future. The worst part is chopping them so they're small enough to be accepted by the site. Someone mentioned using something like putfile. Any comments on that? I've never used them, so I don't know how it works, what it costs, etc... Then I could just post the whole video without having to chop it first.
Posted: Wed Oct 19, 2005 11:09 pm
by BlueCrush
You could also try http://www.streetfire.net
Posted: Wed Oct 19, 2005 11:14 pm
by damronjr
Quote, originally posted by BlueCrush »You could also try http://www.streetfire.netThanks Brian. I'll look at that and putfile after work and see what their terms are.
Posted: Thu Oct 20, 2005 7:35 am
by damronjr
Here's another sucky video from my cam-phone! Going to check on those sites now! BTW, it'll open w/ realplayer.
Attached files Video001.3gp (43.2 KB)
Posted: Sun Oct 23, 2005 10:24 pm
by Vibeman GT
I liked the whine of the S/C It's a shame that it's not available for the 2006 Vibe
Re: Supercharger installed! (Vibeman GT)
Posted: Mon Oct 24, 2005 12:50 am
by damronjr
Quote, originally posted by Vibeman GT »I liked the whine of the S/C It's a shame that it's not available for the 2006 Vibe Just give it time, someone will work something out.
Posted: Tue Oct 25, 2005 6:00 am
by cknight725
Quote, originally posted by Lancer »That is for turbo, though. Your moving much more air @ 10psi with a turbo then you are with a s/c. Yes the psi is the same but the volume is not. psi - Pounds per square inch. READ: Pounds of pressure per a fixed volume.Volume is constant. Turbo PSI is exactly the same as S/C PSI -- I think maybe what you are thinking about is the parasitic drag that S/C cause on the motor since they are belt driven. Turbos don't have any parasitic drag, HOWEVER they have similar HP problems caused by the additional heat that turbos create due to being driven by exhaust gases.
Re: Supercharger installed! (cknight725)
Posted: Tue Oct 25, 2005 2:14 pm
by Faultline
Quote, originally posted by cknight725 »psi - Pounds per square inch. READ: Pounds of pressure per a fixed volume.Volume is constant. Turbo PSI is exactly the same as S/C PSI -- I think maybe what you are thinking about is the parasitic drag that S/C cause on the motor since they are belt driven. Turbos don't have any parasitic drag, HOWEVER they have similar HP problems caused by the additional heat that turbos create due to being driven by exhaust gases.Yes, but given the example of a turbocharged motor, sometimes there will be as much as a 1psi pressure drop after the gas(air) passes thru the intercooler.It is the same volume, but the cooling effect causes the air to condense. Because of heating and cooling, the same volume of air,may have varying psi. Hence Lancer's statement about the SC. A roots blower actually heats up the charge air more than a turbo. Then, in my case, an intercooler cools down the charge even more .Comparing Lancer's SC with my turbo set up, at 10 psi, I do have more air going into the motor. To complicate things more:In the example of "10 psi". We usually measure manifold pressure. Our gauges tell us what the intake manifold pressure is. This pressure tells us what the resistance of air NOT going into the motor. The trick of a good set up is to have more air moving thru the motor, not to have the manifold registering a high psi. For an SC motor, a nice header will allow more volume thru the motor. The same for a turbo motor, but also selecting the correct turbine and impeller in the turbo will facilitate a phenomenon of the air pushing thru the motor faster. Imagine you get your head ported. It will allow more air to flow thru your motor at any given psi. ............
Posted: Wed Oct 26, 2005 11:06 am
by Lancer
I was waiting for you to explain things better.
Posted: Wed Nov 09, 2005 5:05 am
by Yury
Jason, i was wondering how does this supercharger affect regular driving ? I am not racing my vibe, but wouldn't mind getting more power for regular driving.I never drove a supercharged car - would i need to rev it up to get the boost ?And how about gas mileage, does it change much ?
Re: Supercharger installed! (Yury)
Posted: Wed Nov 09, 2005 5:17 am
by damronjr
Quote, originally posted by Yury »Jason, i was wondering how does this supercharger affect regular driving ? I am not racing my vibe, but wouldn't mind getting more power for regular driving.I never drove a supercharged car - would i need to rev it up to get the boost ?And how about gas mileage, does it change much ?It "works" through the entire band, but really you only notice it when your ON the pedal. Let's say you want to pass someone, climb a hill, or just haul (removed), hit the gas and you're off! It's all about throttle position. Harder on the gas = more power. Mileage will only change if you drive it hard. Not a big difference, but with my driving I went from 18mpg to 15mpg when you drive it hard.Welcome to the site, BTW!
Posted: Wed Nov 09, 2005 5:21 am
by Yury
Thanks Jason.So, i guess i would get improvement in my commute.Subjectively, would you say the car gets quite a bit faster in a commute situation ?Btw, i heard that GTs are only better on high rpm. I had a VTEC civic before and this thing was quite useless in regular driving - i definetely didn't feel like red-lining it at all and on low prm it was sliggish. Definitely don't want to spend money on this kind of upgrade.
Posted: Wed Nov 09, 2005 6:00 am
by Yury
btw, another questionwould i have use premium gas after this upgrade ?
Re: (Yury)
Posted: Wed Nov 09, 2005 6:49 am
by Raven
The Vibe GT has too high a compression ratio to supercharge. Yes, you need premium fuel for a supercharged Vibe.
Posted: Wed Nov 09, 2005 7:23 am
by damronjr
Quote, originally posted by Yury »Thanks Jason.So, i guess i would get improvement in my commute.Subjectively, would you say the car gets quite a bit faster in a commute situation ?Btw, i heard that GTs are only better on high rpm. I had a VTEC civic before and this thing was quite useless in regular driving - i definetely didn't feel like red-lining it at all and on low prm it was sliggish. Definitely don't want to spend money on this kind of upgrade.Definitely faster if you gas it! GTs are only better at high RPM where the "lift" kicks in. when it does, it kicks all right! Premium is pretty much required too after a S/Cing
Posted: Wed Nov 09, 2005 7:52 am
by Yury
thanks guys.as i just found out it's not available for 05 so i have some time to think it over i guess .
Re: (Yury)
Posted: Wed Nov 09, 2005 7:57 am
by damronjr
Quote, originally posted by Yury »thanks guys.as i just found out it's not available for 05 so i have some time to think it over i guess .They're supposedly working on making it compatible, but that's yet to be seen. Turbo is always an option, but that's more for racing.
Posted: Tue Mar 25, 2008 2:39 am
by kylethakillah
I know this may sound dumb but im new to sc so is it possable to get one on my 05 base? and if so where can i find one?
Re: (kylethakillah)
Posted: Tue Mar 25, 2008 9:11 am
by damronjr
Quote, originally posted by kylethakillah »I know this may sound dumb but im new to sc so is it possable to get one on my 05 base? and if so where can i find one?Yes, but you have to find one, then you have to get the custom adapter plate for it to work, and I'm not sure, but you MIGHT have to go with an aftermarket ECU as well, not sure on that one though, I thought I saw that somewhere.
Posted: Tue Mar 25, 2008 9:48 pm
by kylethakillah
how much do they run with the adapter?oh and where did you freaking get that hood...It looks amazing!
Re: (kylethakillah)
Posted: Wed Mar 26, 2008 7:44 am
by damronjr
Quote, originally posted by kylethakillah »how much do they run with the adapter?oh and where did you freaking get that hood...It looks amazing!Not sure, you would probably have to find a used SC or someone holding onto a new one somewhere like Ebay or 1 of our sister sites, then you would have to look up more info on the adapter on this site. The hood came from a group buy here on GVC and is made by JSP. I would NOT recommend you buy this hood if they still make it. It is terrible quality, already sent 1 back 2 days after I got it, and this 1 is falling apart!
Re: (damronjr)
Posted: Wed Mar 26, 2008 8:48 am
by kevera
I want a supercharger too,where can I get one.
Re: (kevera)
Posted: Wed Mar 26, 2008 9:52 am
by ajflan
Hahahahahaha...
Posted: Wed Mar 26, 2008 3:18 pm
by AKLGT
wow... old thread!
Re: (AKLGT)
Posted: Wed Mar 26, 2008 9:52 pm
by kylethakillah
can you link me to the original thread? Theres so many on superchargers its like looking for a grain of rice in an Ethiopian camp.
Re: (kylethakillah)
Posted: Thu Mar 27, 2008 3:08 am
by ajflan
Re: (kylethakillah)
Posted: Thu Mar 27, 2008 3:20 am
by kevera
Quote, originally posted by kylethakillah »can you link me to the original thread? Theres so many on superchargers its like looking for a grain of rice in an Ethiopian camp. Here's the link you are looking for.Just do a search next time please,because if you can't find something simple like that,then maybe you shouldn't go f/i. http://forums.genvibe.com/zerothread?id=30399
Re: (kevera)
Posted: Thu Mar 27, 2008 5:48 am
by AKLGT
Quote, originally posted by kevera » Here's the link you are looking for.Just do a search next time please,because if you can't find something simply like that,then maybe you shouldn't go f/i. http://forums.genvibe.com/zerothread?id=30399ya no kidding.
Posted: Fri Apr 11, 2008 7:03 am
by drunkenmaxx
wow, genvibe used to be friendly and helpful. maybe getting webblocked at work isn't so bad...
Re: (drunkenmaxx)
Posted: Fri Apr 11, 2008 7:06 am
by kevera
Quote, originally posted by drunkenmaxx »wow, genvibe used to be friendly and helpful. maybe getting webblocked at work isn't so bad...True factCheers
Posted: Sun Sep 14, 2008 2:49 pm
by SoCal_CJ
looking for TRD supercharger inlet tube ...anyone using a CAI and do not need the TRD supercharger inlet tube the kit came with? RSVP thanks
