Page 2 of 3
Re: (Petrucci914)
Posted: Sat Dec 24, 2005 9:51 am
by 4azdmunky
that is what I tried, Pontiac must have changed the bolt patern and the throttle body size with the 05 DBW. This thing won tmatch up bolt patern regardless of what i do....damn!
Posted: Sat Dec 24, 2005 10:18 am
by Digger
It worked great on mime. ???? By the way My MPG are back up to normal and the power is still better than before.
Re: (Digger)
Posted: Sat Dec 24, 2005 2:01 pm
by Petrucci914
Either you're just missing something with the installation or they sent you the wrong spacer. Does it match the picture of blue crushes? I can get the number off my box if you need it.
Posted: Sat Dec 24, 2005 11:55 pm
by binary
Digger's AWD doesn't have DBW - it still uses the original throttle body.I'm worried that they changed the bolt pattern with our DBW's... I know BC had some photos of his install (page 1 of this thread - http://forums.genvibe.com/zero...age=1 ) it may be worth comparing and see if that's what you got.If it is, this accessory may not fit.What I think is kind of funny about this mod is that it may generate horsepower - but not like anyone thinks it does, or even how it's advertised. Think of how a golf ball's dimples help it fly farther by generating turbulence around it, or how a pickup truck's tailgate up creates a pocket of air behind the cab - giving it better aerodynamics.What this may be doing, in theory, is generating enough turbulance to keep the main stream of the air away from the heated throttlebody - and also giving a faster, smoother tunnel of air going into the throttlebody.The only time you're probably going to see this advantage is when the throttle plate is at 90 degrees (WOT) where it can't cause turbulance.
Re:
Posted: Sun Dec 25, 2005 3:01 am
by 4azdmunky
Petrucci914 -> The part I have is part 97185. Is that what you have?Bianary -> I read through all of the posts here and on matrixowners about this mod. I researched both sides of the argument (it works, it doest work) even researched the science on this product. It was kind of amusing because the exact same arguments are posted in the S10 forums I also frequent. According to the dynamics of airflow and pressure, this thing should not work on my truck (or for that matter on our vibes). So, I bought it for the whistle sound (I know, sounds like a tool decision), installed it, and it surprised the hell out of me how well the thing worked. I left the battery hooked up, so the PCM didn’t reset, so no other variable changed but the truck had such an improvement that the mud tires break loose every easily now on hard top, and you get pushed back into the seat quite hard when it didn’t do it before.Now I know that personal feeling is not true tangible fact, and personal observation is open to interpretation. So, long story short, it should not have any impact in my truck, it does, so even though it should not have an impact on our vibes, I bet it does as well. In the QA/IT/Programming world A+B=C is not always true. In reality A+B= Not C, and A+B=Other Result. or :A+B= It worksA+B= It doesn’t workA+B= It works and we don’t know why (ie, any Microsoft OS)I agree with you, I think this works but no one understands why.If its all placebo,...then bring on the sugar pills!
Re: (binary)
Posted: Sun Dec 25, 2005 3:03 am
by 4azdmunky
yea, what i have looks exactly like that.
Re: (4azdmunky)
Posted: Sun Dec 25, 2005 6:32 am
by Petrucci914
That's what the picture on blue crushes shows, as far as numbers. I dunno. You have the same vehicle that he does, right? Those engines were a bit different, 126HP instead of 130? Did the intake manifold change or somethin?
Re: (Petrucci914)
Posted: Sun Dec 25, 2005 11:24 pm
by BlueCrush
It may be that the DBW have a larger throttle body. I just saw on NewCelica.org that that some are saying the DBW Celica TB's are larger than the DBC Celica TB's. Not sure if they have confirmed it though, nor are they saying if the bolt pattern size has changed.
Posted: Sat Jan 21, 2006 11:14 am
by dug
Sorry, I had to resurrect this old thread:Has anyone tried drilling a hole in this TBI spacer for water injection? I know URD makes one for Toyota's 3.4L, IIRC, but I don't think anyone's done WI through a throttle body spacer. It'd be a clean install if it could be done!http://www.urdusa.com/product_...801ea
Re: (dug)
Posted: Sat Jan 21, 2006 11:31 am
by BlueCrush
No, but that would be an ideal location for it on the Helix.
Posted: Sat Jan 21, 2006 4:10 pm
by northvibe
I just dropped off my car a couple days ago for a warranty fix on a couple parts and they said nothing about my throttle body spacer OR my strut tower bar! good new so far.
Re: (northvibe)
Posted: Mon Jan 23, 2006 10:40 am
by Lancer
They probly didn't even know it's not suposed to be there. The one's that I've seen don't have any experiance working on Vibes.
Re: Helix Power Tower Plus (BlueCrush)
Posted: Wed May 31, 2006 1:04 am
by hubcaphead
I wanted to take the time out to thank you for posting a link to our website. I ant to offer you a $10.00 off coupon for part number spe-97185 which is the picture that is shown. The code is SSGEN0506Please use this whenever and as many people that want to use it can. Thanks again for the post!!http://www.hubcapsplus.com
Doesnt look like they make Helix Power Tower Plusone for the 05' Vibe-I emailed
Posted: Mon Jun 12, 2006 12:38 am
by lexicon
I emailed the manufacturer and no response.Does anyone know different?
Posted: Mon Jun 12, 2006 12:56 am
by northvibe
I want to see a DBW so i can see the diff... I would think its the bolts. thats whats making it not fit the 2zz.
Re: (northvibe)
Posted: Mon Jun 12, 2006 2:24 am
by scherry2
just put some gas in since the install of northvibes used helix power tower. I go about 31 to 32 MPG in town driving rough est.(40 MPH or less) now to try it out on the Interstate. i also noticed a little more pep in the low RPM range. It isn't hurting so i'm happy with my purchase.
How do you define Pep?
Posted: Tue Jun 13, 2006 11:38 pm
by lexicon
Just a question,How can you physically tell youve got a 1-3hp increase in a low hp engine?Is the pep basically extra noise, since its not dynoed and wasnt taken to the drag races for timed trials, what are you actually measuring?I am not trying to challenge you on this, but , if someone had installed the unit on your car, without your knowing, would you have been able to tell the difference.To me, more efficiency "should" translate to better gas mileage. So, if your gas mileage consistently increases over a period of say 3 or more tanks of gas, then , this is a measurable change .For example. I also have a >200,000 mile Corolla. I religiously got 30 mpg no better, sometimes 29mpg.After doing Seafoam in the engine intake, I immediately saw 33 mpg and 31.5 mpg. Now , Months later, I am seeing at least 31.5 mpg.So, here, I saw a measurable increase.Thanks
Re: How do you define Pep? (lexicon)
Posted: Wed Jun 14, 2006 12:20 am
by scherry2
placebo effect?
Re: How do you define Pep? (scherry2)
Posted: Wed Jun 14, 2006 7:12 am
by Digger
I saw a big diferance in the pep of my 05 AWD. It shifts better. Does not bog down on slight inclines. The MPG dropped at first then got better. I can tell a big differance in mine. I did put a short ram on at the same time though.
How to troubleshoot or determine how a change affects the final result
Posted: Wed Jun 14, 2006 11:49 pm
by lexicon
Part of basic troubleshooting is to only change one thing at a time.If you change multiple things simultaneously, you dont know where the change in the system came from.So, in this case, we dont know if the perceived improvement is from the stack or spacer.What is your mileage change (based over several tankfulls)?
Re: How to troubleshoot or determine how a change affects the final result (lexicon)
Posted: Thu Jun 15, 2006 11:14 am
by Digger
I went up 4 MPG 25-26 to 29-30
Re: How to troubleshoot or determine how a change affects the final result (Digger)
Posted: Thu Jun 15, 2006 12:15 pm
by BlueCrush
After I installed mine, I experienced more torque in the low and mid rpm range. I also experienced a 2-3 mpg increase.
What will it take to get the manufacturer to produce a Helix Plus for 2005 and 2006 years
Posted: Mon Jun 19, 2006 1:48 pm
by lexicon
I sent an email to the mfr. and no response.Does anyone know an internal contact at Helix?
Re: What will it take to get the manufacturer to produce a Helix Plus for 2 ... (lexicon)
Posted: Mon Sep 18, 2006 6:33 am
by vibe Freak
All I can say is this thing works great. I have a Base auto vibe with the spacer and intake, and the car really came to life after the spacer. Pulleys are next then wheels. But it is a no brain-er get it you will not be disappointed. Thanks to Blue crush for telling me about this great mod. Dominic
Posted: Mon Sep 18, 2006 7:17 am
by LUVROK
Does anyone offer a 2ZZ model?What's the bolt issue related to the 2ZZ? Does the throttle body have a different bolt pattern? I would be happy with a blank with no holes drilled so I can drill or mill my own.
Posted: Mon Sep 25, 2006 3:30 am
by yeye
Did this make any difference in noise for those running this with intake or any other mods. Wondering if it makes the car louder or not?
Posted: Mon Sep 25, 2006 3:36 am
by northvibe
theres no difference in noise when i used it.
Re: (northvibe)
Posted: Mon Sep 25, 2006 5:06 am
by BlueCrush
Mine made slight BOV type/light whistle sound when I accelerate hard and let off the gas. Other than that, no noises.
Re: (BlueCrush)
Posted: Mon Sep 25, 2006 5:13 am
by Mrizzle05
Quote, originally posted by BlueCrush »Mine made slight BOV type/light whistle sound when I accelerate hard and let off the gas. Other than that, no noises.LOVE that sound... all i gotta say
Posted: Mon Mar 26, 2007 3:42 pm
by VforVIBE
Quote, originally posted by BlueCrush »The install was fairly easy. It took about 1/2 hour. I had to modify my CAI by cutting off about an inch.The spacer is 1" thick and is aluminum.Quote, originally posted by Digger »I saw a big diferance in the pep of my 05 AWD. It shifts better. Does not bog down on slight inclines. The MPG dropped at first then got better. I can tell a big differance in mine. I did put a short ram on at the same time though. do you think a short ram would need to be cut down?Edit: they don't make it for the 05 & 06 do they?
Re: Helix Power Tower Plus (VforVIBE)
Posted: Mon Mar 26, 2007 9:33 pm
by GrayFox
BC's vibe is an 05 but he has cable throttle....
Re: Helix Power Tower Plus (ANO_Vibe)
Posted: Mon Mar 26, 2007 9:41 pm
by BlueCrush
There is one out for the '05-'07 DBW. If you have more than 1" of space between your filter and your fusebox then you should be fine with no cutting. If not, you will need to trim some off.
Posted: Mon Mar 26, 2007 11:37 pm
by VforVIBE
Quote, originally posted by ANO_Vibe »BC's vibe is an 05 but he has cable throttle....AWD Quote, originally posted by BlueCrush »There is one out for the '05-'07 DBW. If you have more than 1" of space between your filter and your fusebox then you should be fine with no cutting. If not, you will need to trim some off.Awesome, thanks man... I was looking over your Poor mans mod list and I was like nope, can't do that or that... but I can do this, yay!
Posted: Sat Mar 31, 2007 10:35 am
by MAVibe
Any idea who has the best price for this spacer(05-07)? I actually haven't found the one for the '04-'06 Corolla 1ZFFE DBW #97188 available anywhere.....
Re: Helix Power Tower Plus (MAVibe)
Posted: Sat Mar 31, 2007 9:13 pm
by kevera
Re: Helix Power Tower Plus (kevera)
Posted: Sat Mar 31, 2007 10:48 pm
by MAVibe
That's for the 2002- 2004 models....part #97185.... I have the '06 1zf....
Posted: Sun Apr 01, 2007 1:03 am
by kevera
IZF..huh,you mean 1zz.I don't think it matters.I think it will work.
Posted: Sun Apr 01, 2007 1:16 am
by BlueCrush
Quote, originally posted by MAVibe »Any idea who has the best price for this spacer(05-07)? I actually haven't found the one for the '04-'06 Corolla 1ZFFE DBW #97188 available anywhere.....Contact these guys to find out where you can get it: http://www.streetandperformanc...d.htm
Posted: Sun Apr 01, 2007 2:13 am
by MAVibe
Thanks BC! That's exactly what I did this morning.....waiting for response.
Posted: Sun Apr 01, 2007 2:32 am
by kevera
Or ask KeithVibe which one he used,I think he has an 06 DBW.edit:Nevermind,he has an AWD.SorryThat's why I gave you the link,I thought he had DBW,my mistake.
Posted: Sun Apr 01, 2007 3:09 am
by ProtonXX
I have a scangauge 2 & I can try this out to get some numbers on it.
Posted: Sun Apr 01, 2007 3:33 am
by keithvibe
LOL... Sorry I do have AWD... This is why I didn't chime in on the topic. But since I have installed the spacer I would pay the money just for the sweet POV sound it makes on the highway with out overdrive engaged. I noticed slight gains in the low end of the RPM range.
Re: Helix Power Tower Plus (keithvibe)
Posted: Sun Apr 01, 2007 6:16 am
by MAVibe
I heard back from Street&Performance---the spacers are not available and there is no release date for the Throttle Body Spacer for the late model 1.8's w/ DBW (2005-2007).....
Posted: Sun Apr 01, 2007 6:22 am
by BlueCrush
Quote, originally posted by MAVibe »I heard back from Street&Performance---the spacers are not available and there is no release date for the Throttle Body Spacer for the late model 1.8's w/ DBW (2005-2007).....What? Bummer! Well, then why do they have it listed for the 1zz DBW celica?
Posted: Sun Apr 01, 2007 12:22 pm
by Vivid_Art
So is this spacer really worth the money? you guys think it would do much for a base Vibe w/ a Cai and Header installed?
Re: (Vivid_Art)
Posted: Sun Apr 01, 2007 1:08 pm
by ProtonXX
Dunno yet but I did the Coolant bypass & seafoam today & my scan gauge was throwing out a retarded 100mpg at 45mph & 2gph idle. Old numbers was 40ish & 3GPH idle. It obviously needs re calibrating lol.The temps reading for the engine water & SR stayed the same 200F & 100F
Re: (ProtonXX)
Posted: Thu Apr 05, 2007 5:49 pm
by ProtonXX
Just did a road trip to cali & back. Got 30 MPG coming back which never ever happened before. Coolant Bypass MOD for the win :D
Re: (ProtonXX)
Posted: Thu Apr 05, 2007 11:09 pm
by manicdan
any updates on a 2zz version yet?
Re: (manicdan)
Posted: Sun Jul 08, 2007 8:10 am
by His_and_Her_Vibes
...Bump... (my first - hope I did it right!) Any release date for the Throttle Body Spacer for the late model 1.8's w/ DBW (2005-2007).....???? I've ordered a TBS for my Wife's '04 Vibe. Hopefully it will improve gas mileage. It has a K&N drop-in filter, but I will likely install either an AEM, INGEN or Cosmo CAI very soon. (as soon as I decide which one!)
Re: (His_and_Her_Vibes)
Posted: Sun Jul 08, 2007 8:13 am
by kevera
Bump for what
