Page 4 of 4
Posted: Sat Aug 26, 2006 10:27 am
by csharrigan
Damn, I got MUCHO Calls, however, not ONE that is USEFUL, Where is my new PCM? LOL
Re: (csharrigan)
Posted: Tue Aug 29, 2006 12:24 pm
by csharrigan
Received call, My car is going in on Thursday morning for a "brain transplant"
Re: (csharrigan)
Posted: Thu Aug 31, 2006 12:47 pm
by csharrigan
PCM installed today.... as were my tires balanced, and rotors turned... started to get some jitters... The car is "behaving" so far, and I will keep my fingers crossed, I have noticed however, that the warm start time has decreased overall, that doesn't mean it won't have an episode, I hope for the best, and will keep posted.
Posted: Thu Aug 31, 2006 12:49 pm
by northvibe
I hope this fixed it!
Re: (csharrigan)
Posted: Thu Aug 31, 2006 1:29 pm
by Toasted7
UPDATE:Mine is still starting every time so far since I'm on my second PCM.
Re: (Toasted7)
Posted: Thu Aug 31, 2006 10:23 pm
by new05vibeowner
Mine's on the rack at the dealer now getting a new brain. Will let the group how it works out.
Re: (new05vibeowner)
Posted: Fri Sep 01, 2006 5:20 am
by new05vibeowner
New PCM installed and so far, no starting issue. Also, car seems to have a LOT more power, especially at lower RPMs.
Posted: Sat Sep 02, 2006 11:59 am
by csharrigan
Still behaving, notably different start times/ engine catch, still crossing fingers though.
Re: (csharrigan)
Posted: Sat Sep 02, 2006 4:11 pm
by Toasted7
Quote, originally posted by csharrigan »Still behaving, notably different start times/ engine catch, still crossing fingers though.Is it starting faster now?
Re: (csharrigan)
Posted: Sat Sep 02, 2006 10:10 pm
by jbyerley
Is your overall performance ok? How is the miles per gallon?
Re: (jbyerley)
Posted: Sun Sep 03, 2006 2:56 am
by csharrigan
Has started everytime so far, and definately faster. My car always gave me trouble in very hot/humid weather, and this week has been very atypical.. cold/wet, I won't be completely convinced until it does it's good a week or so. Performance didn't change in mine, just a noticable change in starting behavior. Sorry, I don't keep track of MPG...
Re: (csharrigan)
Posted: Sun Sep 03, 2006 2:04 pm
by Toasted7
I think my MPG has gone down since my PCM was replaced... will know for sure after a few more tanks.
Re: (Toasted7)
Posted: Sun Sep 03, 2006 9:51 pm
by krisf
I have had mine for about a week also. Things seem ok, but the MPG has decreased from 30MPG to about 27MPG. I will definety bring that up to them when they call.I have noticed when I start mine up it revs up real quick then slows down. I am not sure if this is normal.
Posted: Mon Sep 04, 2006 12:10 am
by csharrigan
I notice the rev too, however, my car always does that when cold, and never did w/ hot starts, and when it was difficult to start it would flutter at a less than normal rpm for a couple seconds. For the record though, I have a few 05' Corolla's around, none with the starting issue, and all do the little rev when hot.CH
Re: (csharrigan)
Posted: Mon Sep 04, 2006 10:24 am
by new05vibeowner
My PCM went in Friday, and so far, car is running a lot better. Mileage seems to have gone up from 30 ave to 31. Just filled the car today and will report back on the 1st full tank since the PCM replacement.
Posted: Thu Sep 14, 2006 12:21 pm
by csharrigan
Still no problem, how is everyone else making out?
Re: (csharrigan)
Posted: Thu Sep 14, 2006 12:56 pm
by Toasted7
Well, on this tank my mileage went down to 26mpg from 28mpg that I usually get.
Re: (Toasted7)
Posted: Fri Sep 15, 2006 12:27 am
by new05vibeowner
Mine definately starts better, and I haven't experienced the drop in MPG that others have. My only comment is that no one from Pontiac has bothered to make contact with me since the initial phone call. It would've been nice, and would have gone a long way in making me feel like a valued customer of Pontiac, if someone in Detroit had made a follow-up call.
Posted: Fri Sep 15, 2006 12:47 am
by csharrigan
I really dont care about the follow up call.... my car finally starts correctly.
Re: (csharrigan)
Posted: Fri Sep 15, 2006 12:52 am
by Mrizzle05
i definately need to get this done soon... when i go to the dealer what would i specifically tell them or say to them about the hot start??? and if they give me crap what else can i say?thanks guys... glad you got em fixed now.
Posted: Fri Sep 15, 2006 12:12 pm
by csharrigan
I would tell them to look into cases that it wasn't fixed with first PCM replacement. I believe it should be documented, some sort of PCM revision. Not positive though, worst case scenario is calling into the executive office and finding out who can get the correct part ordered and sent to your dealer.CH
Re: (csharrigan)
Posted: Sat Sep 16, 2006 1:54 am
by Toasted7
I'm down to 26mpg now with the replacement of the PCM... lost about 2-3mpg now
Re: (Toasted7)
Posted: Sat Sep 16, 2006 4:58 am
by Tubaryan12
Quote, originally posted by Toasted7 »I'm down to 26mpg now with the replacement of the PCM... lost about 2-3mpg now how do you drive the car? are you a hard driver? I ask this because I may have this problem, not nearly as bad as some, but I'm not willing to give up 2-3 mpg for something that happens less than once a week and the longest I've had to crank is about 7-8 seconds...most are less than 3. Most of my trips are one way, 30 miles, all freeway, then the car sits for 8 hrs and then back home again.
Re: (Tubaryan12)
Posted: Sat Sep 16, 2006 1:37 pm
by Toasted7
I guess I'm a hard driver overall... the loss in mpg was just something I noticed in my first few tanks, but I'll keep an eye on it and see what happens. I'll be sure to keep you posted.
Posted: Sun Sep 17, 2006 12:54 am
by cmhj2000
Had an "intermittent" hot start problem with my 05 2 WD/Auto after about 1K miles. Original dealer had no clue. Went to another dealer and he told me about the bulletin on the PCM.After getting a replacement PCM I've had no issues with warm or hot start & mileage remained in the mid 30s highway.
Re: (racersforford)
Posted: Sun Sep 17, 2006 1:58 am
by KrazyB
I have had the same problem off and on, I thought for the longest time that it was because I wasn't cranking it over long enough. But now I know the truth to the problem. I complained to the dealer also and they told me to deal with it. If it doesn't happen for them then there is no problem just like everything else with them.
Posted: Sun Sep 17, 2006 11:12 am
by csharrigan
Umm, yea, so weirdness.... I must say my starting problem is fixed, but now my car smells like rotten eggs-- what gives? I Usually notice it right after getting out of the car after it had been running, or when I start it and it was already hot. I must admit I'll tolerate the smell as it's much better than the no start, but it is definately new, and a result of the other.
Re: (csharrigan)
Posted: Sun Sep 17, 2006 11:53 pm
by Mrizzle05
CS: its probably the cat... i hear thats the problem if you smell the rotten eggs.Ill post the link in a fewEDIT: heres a link i foundhttp://forums.genvibe.com/zerothread?id=23410
Re: (Mrizzle05)
Posted: Mon Sep 25, 2006 11:33 pm
by new05vibeowner
I received a call from Josh Farner in the GM Executive Group this morning. He wanted to make sure that the replacement of my PCM has indeed solved the problem. Told him so far, so good.Nice to see that the squeaky wheels do indeed get the grease.
Posted: Tue Sep 26, 2006 1:58 pm
by Toasted7
I got the same follow-up phone call... I told him that it is starting now, but my MPG has went down about 2-3 mpgs.
Re: (Toasted7)
Posted: Mon Oct 16, 2006 8:50 pm
by jbyerley
How is the new PCM working out for you? Any problems? MPG?Jbyerley
Posted: Mon Oct 16, 2006 8:51 pm
by jbyerley
How is your MPG? Any problems with the new PCM?
Re: (jbyerley)
Posted: Mon Oct 16, 2006 10:38 pm
by Toasted7
MPG still down after a few tanks, which sucks
Re: (Toasted7)
Posted: Tue Oct 17, 2006 12:43 am
by new05vibeowner
My MPG is exactly where it was prior to PCM replacement. I average 30 in combination of city/highway driving.
Posted: Wed Oct 25, 2006 8:15 pm
by jbyerley
I contacted Pontiac and they are playing dumb. Can you tell me what dealership and city located that you had your new improved PCM installed at? Thanks
Re: (jbyerley)
Posted: Wed Oct 25, 2006 9:40 pm
by new05vibeowner
Call Josh Farmer in the GM Executive Group directly. His # is (313) 667-7153.
Posted: Thu Oct 26, 2006 8:06 pm
by jbyerley
thanks
Posted: Mon Nov 27, 2006 8:38 pm
by jbyerley
Can you or any body else tell me what the part number of the new pcm is?The local dealer ordered one for me and I want to make sure it is the correct one. The part number should be on your dealer invoice. I have left messages with Josh Farner he doesn't return phone calls.Thanks
Re: (jbyerley)
Posted: Fri Dec 29, 2006 11:40 am
by jbyerley
i WANT TO THANK ALL OF YOU THAT GOT YOUR PCM REPLACED.IF YOU COULD JUST LOOK AT YOUR SERVICE RECEIPT FOR THE PART NUMBER IT WOULD BE APPRECIATED. I"M SURE IT WON'T TAKE TO LONG AND WOULD REALLY HELP. I DON'T THINK GM IS GOING TO TAKE THE PART OFF OF YOUR CAR IF YOU TELL ME.
Posted: Fri Dec 29, 2006 11:58 am
by CAN-AWD-VIBE
call a GM parts department... ask for a PCM for your car. Then ask if it was superseeded by any other number.
Posted: Sat Dec 30, 2006 10:26 pm
by 2002sportside
Part numbers on the TSB are...88974621 with auto and ABS88974622 with auto88974623 with manualPNs were replaced since, they should now be:889747618897462588974626Unless they were changed again...
Re: (CAN-AWD-VIBE)
Posted: Sun Dec 31, 2006 10:05 pm
by jbyerley
Thanks
Re: (2002sportside)
Posted: Sun Dec 31, 2006 10:07 pm
by jbyerley
Thanks
Re: (jbyerley)
Posted: Mon Aug 13, 2007 3:08 am
by Bloo_Ink
FYI for anyone with a 2005 or older Vibe w/ auto trans (non-GT)My2005 Toyota Matrix w/ automatic transmission, has the same problem.- intermittent issue which has no pattern- Occurs when: the engine is warm and is turned off for usually about 20 minutes(sometimes hours or sometimes minutes)- trying to restart the warm engine requires extended crank time and multiple tries- I have no other keys on the key ring- I always turn the key until the beeping stops then crank the engine (does not help)
http://www.youtube.com/watch?v=sCa3mYJJRU0File download linkshttp://
www.megaupload.com/?d=W8A77KZLhttp://de ... es/1465306
Posted: Mon Aug 13, 2007 9:24 am
by stewpid
guys i work for GM and i had this same problem, most of the time its a problem witht the PCM it jsut needs to be reprgramed just take it to ur pontiac dealer and they will reprogram it for ya, there is a staight TSB that outlines the problem for a long crank time, especially with the motor hot, there is another one for 2005-2006 that u need to replace the fuel pump
Re: (stewpid)
Posted: Mon Aug 13, 2007 11:25 pm
by Toasted7
The problem I was having with my dealership is that they said they could not duplicate the problem and were very unwilling to help me at first. It took a letter of complaint to get them to replace the PCM for me. It still has a little difficulty starting, but it does start none the less. You think they will give me difficulty with getting the fuel pump replaced if they can't duplicate the problem because it is still intermittent?
