These are nice.2006 Cadillac XLR-V Compact Convertible Engine- 4.6L displacement double overhead cam (DOHC) V8 cylinder configuration gas engine 32 valves variable valve timing supercharger.DriveTrain- rear wheel drive rear limited slip differential Exterior- Length: 177.7 in. Width: 72.3 in. Height: 50.4 in. Wheel Base: 105.7 in. Ground Clearance: 6.61 in. Curb Weight: 3647 lbs. Interior- Front Head Room: 37.6 in. Front Hip Room: 53 in. Front Shoulder Room: 54.3 in. Front Leg Room: 42.6 in. Luggage Capacity: 4.4 cu. ft. Maximum Cargo Capacity: 12 cu. ft.Performance- Base Number of Cylinders: 8 Base Engine Size: 4.6 litersBase Engine Type: V8 Drive Type: RWD Turning Circle: 39 ft. Fuel Tank Capacity: 18 gal.2006 Cadillac STS-V Large Sedan Cadillac has made it clear that it intends to give the V-Series treatment to more than just the CTS, so it wasn't much of a surprise when heavily modified prototypes of the STS were photographed making the rounds at Germany's Nurburgring test track. Power is expected to come from a supercharged version of Cadillac's 4.6-liter Northstar V8 putting the STS-V in the 400-500-horsepower range. And don't be surprised if it shows up with a six-speed manual transmission either as Cadillac fully intends for this car to be a true competitor to BMW's M5 super sedan. Look for its debut at next year's Detroit auto show in January.
