I don't know if anyone else has posted this, but I just stumbled across cosmo's Underdrive Pulley for the base vibe. I was just on the site checking out the short-ram I want, and there it was. $55 to boot. Unorthodox racing is a few hundred dollars, so is this too good to be true? http://www.cosmoracing.com/pro...d=813
Quote, originally posted by Flip-Side »I don't know if anyone else has posted this, but I just stumbled across cosmo's Underdrive Pulley for the base vibe. I was just on the site checking out the short-ram I want, and there it was. $55 to boot. Unorthodox racing is a few hundred dollars, so is this too good to be true? http://www.cosmoracing.com/pro...d=813 Its a good deal but we had a member blow his engine cause of these pulleys and also other people with same engine so I would not recommend it unless you have extra cash lying around to buy a new engine in case yours blows.http://forums.genvibe.com/zerothread?id=11122
After reading that and some other information on pulleys, there is no way I will install one on my car. I didn't realize that you would lose the harmonic balancer on the crank. It's there to prolong engine life, and I'm not gonna chance it for a couple HP. Thanks wicked.
