intercooler
Supercharger, turbo, nitrous, and anything that has to do with forced induction
rcasciola
intercooler
Post by rcasciola »
does anyone have an intercooler without a turbo...what kinda of gains do u think it would produce...cause if i can recal...the matrix had an xs engineering intercooler b4 the whole turbo kit.
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
Devlop
Re: intercooler (rcasciola)
Post by Devlop »
I have a spearco intecooler. I'm not sure on the gains, but I know it helps a lot. The only problem with having an ic is that it creates a but more lag because of all the extra piping that is needed to run the air to it, but its worth it. I know faultline has one also. He might be able to give a better answer.
Mavrik
Re: intercooler (Devlop)
Post by Mavrik »
where did you guys mount that intercooler? right in the front before the rad in that large gap in there?
Devlop
Re: intercooler (Mavrik)
Post by Devlop »
Yeah, its attached to the front bar on the back side. Plenty of room.
Mavrik
Post by Mavrik »
you got pics of it on your car domain page? I'll have to take a look.
AKLGT
Post by AKLGT »
ya, so what would an ic do for a non turbo/s/c vibe? will it make any diff?
AKLGT1998 Subaru 2.5RS
Devlop
Re: intercooler (trdvibe)
Post by Devlop »
I don't think it would be any better than a cai. When you force air, it gets compressed, which of course heats up. That's why the ic is so useful on fi'ed cars. I don't think I have any pics of the ic from inside the engine bay. If I have time, I'll take a couple. I think my imagestation has some closeups of the ic from the outside.http://www.imagestation.com/album/?id=4289053071
AKLGT
Post by AKLGT »
hmm. so you wouldn't have a cai then, right? the ic is just a much bigger badder cai in a way! or is that wrong?
Devlop
Post by Devlop »
Well, actually, I do have a cai. Most turbo systems have a short ram for the intake, but Rick designed this kit to have a cai also. The filter sits behind the left fog light, similar to the cai's for our cars. Of course, the piping is custom though because it has to run to the turbo instead of the throttle body. Basically, any little bit helps with fi.
savedbyzero
Post by savedbyzero »
isn't gonna do you any good...but you could gain some ricer points! J/K!
THIS IS WHAT I DO...http://www.studiothisis.com
Mavrik
Re: intercooler (savedbyzero)
Post by Mavrik »
Quote, originally posted by savedbyzero »isn't gonna do you any good...but you could gain some ricer points! J/K! Mmmmmmm.... rice...
rcasciola
Post by rcasciola »
what about headers...would that do anything....i have herd anywhere from 6-14 hrs pwr...r there any for the vibe/trix?
goodvibe
Post by goodvibe »
Maybe the low side of that for a base but the 2zz already has a factory header that's hard to beat.
Faultline
Re: intercooler (goodvibe)
Post by Faultline »
Having an IC w/o a turbo or SC is useless. A turbo , or SC will heat up the air during the compressing process. An IC will cool down the air before it goes into the motor. the air is already cool for a N/A motr, but CAI's are designed to suck in the coolest air possible for N/A motors, or in Devlops case , before the turbo. Either way, the idea is to get the coolest air into the motor, as the cooler air is denser=more power.
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
Faultline
Post by Faultline »
Quote, originally posted by Mavrik »where did you guys mount that intercooler? right in the front before the rad in that large gap in there?here ya go! http://fourms.genvibe.com/zero...5.jpc
greenfire
Re: intercooler (Faultline)
Post by greenfire »
An intercooler for the SC would be an interesting idea. I read that the new Chevy Cobalt SS (with supercharger) will be intercooled and boost will go up to 9 or 10 psi. That sounds like its going to be a nice set up.
2005 Flint Mica Scion tCTRD exhaustFormer Car: 2003 Matrix xr4wd
