Anybody know where i can find specs on how big car radios are?I'm looking for the dimensions (ie. height, widht, depth, etc.)The reason im looking for this is that im going to see if i can mount my police scanner under my radio.btw, It's legal where i live to do that as long as you have a amateur radio license.
Car: Two-tone Base Abyss, Moons and tunes, Power packageMods: 20% tint, Reflective Black GrafxWerks Overlays, German Hella Horns, Hardwired Valentine One, red interior dome lights, custom cargo floormat, police scanner, ham radio, cellphone kit and a bunch of antennas on topWishlist: Rubber floormats, million dollars
Sure...go through Crutchfield, I think they have the dimensions on the "specs" page. Could be wrong tho..
Quote, originally posted by Jahntassa »Sure...go through Crutchfield, I think they have the dimensions on the "specs" page. Could be wrong tho..couldnt find anything on crutchfield.. it just tells you the chassi code, not how big it is i have some more time now after work so ill try to find something on google.
No, im looking for the size of a half height radio.basically im trying to figure out if a half height radio plus my uniden 780 scanner will fit. i'm aware that i will probably have to move the uniden into a shell from a old radio, but im not sure the front panel of the 780 is small enough to fit underneath a radio.
The vibe is a dual-DIN radio. You can fit two standard-size ISO/DIN mount radios into the spot. If your scanner is smaller than a standard aftermarket radio, it'll fit fine.
Quote, originally posted by Jahntassa »The vibe is a dual-DIN radio. You can fit two standard-size ISO/DIN mount radios into the spot. If your scanner is smaller than a standard aftermarket radio, it'll fit fine.The problem is that i need to know what the size of a standard din radio is..
most all din radio will be about the same size.. just for reference Her's the dimensions on the Single-Din unit I have:HxWxD = 52 mm x 188mm x 161mm (2 1/16 x 7 3/16 x 6 3/8)Hope this helps.Omar
