Last night's commute was really really windy. Hmm, why is my left hand getting cold? Where is that draft coming from? After some searching , I discovered a massive cold air leak around the door handle on the driver's door. Anyone else notice this? You'd probably only notice it if the wind is broadsiding the car, because when I turned into the wind, the draft went away.
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
I had the exact problem the other day. The wind was around 40-50MPH gusts and I could feel a breaze coming through the door handle. When the wind was behind me, I no longer felt it, only when the wind was hitting the drivers side. That stupid wind also cost me a quarter tank of gas for a 55 mile trip
Most likely the draft is from high velocity wind entering the inside of the door either from the wheelwell area or at the front of the door. If you look at the hinge when your door is open you'll find a hole in your door where all the wires pass through. This doesn't happen as much with today's cars, that's why you only noticed it when there was high wind hitting your car. My '76 Impala, '74 Monte Carlo, '77 Malibu, and '84 Monte Carlo all had a breeze coming from the handle at freeway speeds. The '92 Tracker, '92 Sable, and '00 Sunfire almost never had that problem.Hope this helps,ND
Nervous Dog2003 Monotone Lava GT w/ M&T and PowerMods: 18" Bronze Tenzo-R Mean Six rims w/ Kumho MX12" Rockford Fosgate Punch Sub in slot ported box2 - Rockford Fosgate Punch 201S amps2 pair - Rockford Fosgate P162C in front/rear doorsSony Xplod 5710 head unitHidden Hitch
