AC compressor or fan assembly? (noise)
takearushfan
Post by takearushfan »
Hi all. My 2006 Vibe has lately been making an obnoxious noise sometimes when the AC is on. It doesn't always do this but it's frequent enough to be irritating. I attached a link to a YouTube video to show you. I read it can be the AC compressor (God help me if that's the case) or possibly the assembly which would be more ideal. Does that seem accurate based on this video? What else might it be? The plastic shroud itself is secure as is the radiator itself, I will say though that the plastic fan blade can be slightly moved back a bit if you try to pull it towards you even slightly. It looks almost like the blade might be knocking on the shroud's plastic. Please take a look and advise. I appreciate it.
The video record recording:
[youtube]https://youtu.be/DKzgCA5-eWQ?is=0ehWlQC7Itei0xfn[/youtube]
jolt
Re: AC compressor or fan assembly? (noise)
Post by jolt »
From that video, it looks like the fan assembly should be replaced. Video is never a good way to identify a noise source. You could try unplugging the power wiring to the fan motor and then run the A/C again. Checking if noise has gone away. As these Vibes get older, it is harder and harder to locate parts. If all else fails, check your car salvage yards for a used replacement fan assembly. You can also try this site to check salvage yards: https://www.partshotlines.com/
takearushfan
jolt wrote: ↑Thu Oct 08, 2026 3:49 pm From that video, it looks like the fan assembly should be replaced. Video is never a good way to identify a noise source. You could try unplugging the power wiring to the fan motor and then run the A/C again. Checking if noise has gone away. As these Vibes get older, it is harder and harder to locate parts. If all else fails, check your car salvage yards for a used replacement fan assembly. You can also try this site to check salvage yards: https://www.partshotlines.com/
Thanks so much. I'm hoping thats what it has as it's relatively affordable compared to a compressor, that's for sure.
jolt
Post by jolt »
Be sure to unplug the fan and test it to make sure the fan is the problem before you buy a replacement. Videos are worthless to identify a noise source.
Just for information, here are new fan assemblies for a 2008 Vibe, so new ones should be available for yours: https://www.rockauto.com/en/catalog/pon ... embly,2181
takearushfan
jolt wrote: ↑Fri Oct 09, 2026 11:23 am Be sure to unplug the fan and test it to make sure the fan is the problem before you buy a replacement. Videos are worthless to identify a noise source.
I may or may not have not thought to make sure it's the fan, jumped the gun, ordered it and it arrives tomorrow ;) I'm not taking it to anyone either. I'm gonna try to replace it myself. I see the bolts, clips etc are in better reach than I expected so wish me luck 😬
