Hello All.
I'm doin' a full brake job on the 2006 Vibe, with ABS. I'm rebuilding Master Cylinder. No leaks or dark fluid, just preventative maint, given everything else will be new. Questions: Does anyone know if 2006 Vibe with 4-wheel ABS has same Master Cylinder Specs / size (bore?) as non-ABS Master Cylinder?
I want OEM Toyota repair kit: 04493-60270 / 0449360270. But three's no mention of an OEM Toyota repair kit that specs for 2006 Matrix cars with 4-wheel ABS? (my equivalent Vibe). In my experience, most ABS Master Cylinders usually have bigger bore than non-ABS.
Thanks in advance. This is the only part left, before the nearly new 20yr old Vibe gets her first full brake job. -Will
