Another Check Engine is really.....
ZZvroom
Post by ZZvroom »
My 2003 GT has a Check Engine signal.
While replacing the stabilizer bar links, the rear brake backing plates, and many other things, we found the cause.
A rodent has chewed open several of the lines from the charcoal canister.
More things to fix!
Re: Another Check Engine is really.....
I can relate to that! :o A post from FOUR years ago in case you never had the chance to check it out! viewtopic.php?f=17&t=47004&p=527026&hil ... er#p527026
