Had To "Jimmy" Door: Help With Door Dings/Scrapes?
2010VibeRed
Post by 2010VibeRed »
Hey all. Hope your Vibes are still giving you as much fun as mine is.
I stupidly locked my keys in my car and didn't have another set of keys. With the help of friends I eventually did get it opened, but the driver-side passenger door was damaged a bit due to use of a crowbar. I have included a photo of the damage marks, which is on the black area of the door.
How do you suggest I go about repairing this section? Is there a touch-up/plastic-like (or rubber like?) product I can use?
Further, I never had a second key. When I look to get one made, they seem to be very expensive especially with the remote opening/locking feature. Can I simply get a copy made locally; a basic one that I can use to manually open the door?
Thanks for reading and for any help you can offer. All the best.
VibeNation2024
Re: Had To "Jimmy" Door: Help With Door Dings/Scrapes?
Post by VibeNation2024 »
I can't help with the 2010 key questions since I have an 08 and 07 and they are different with the security/fob.
As far as the trim, I have used a flat black touch up pen on some areas that had chips and it is not noticable but your area has a little more damage. I would suggest trying to smooth out where the coating is bunched up and see how it looks from there. I realize it won't cover everything but you might assess how bad after to you that to see if you wanted to use a touch up pen, perm marker, leave it, etc.
Last edited by VibeNation2024 on Sat Sep 07, 2024 9:39 am, edited 2 times in total.
2010VibeRed
VibeNation2024 wrote: ↑Fri Sep 06, 2024 5:19 pm I can't help with the 2010 key questions since I have an 08 and 07 and they are different with the security/fob.
As far as the trim, I have used a flat black touch up pen on some areas that had chips and it is not noticable but your area has a little more damage. I would suggest trying to smooth out where the coating is bunched up and see hot it looks from there. I realize it won't cover everything but you might assess how bad after to you that to see if you wanted to use a touch up pen, perm marker, leave it, etc.
Thanks for your reply and help VibeNation2024. I'm going to smooth the area out a little. Then I'll try those ideas.
Thanks again my friend.
